Something is off with my Paradigm UltraCube 12.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-06-2012, 06:28 AM - Thread Starter
raschkec's Avatar
I have a Paradigm UltraCube 12 hooked up through my Denon 3312. I've configured the system using the audyssey system. But I'm getting what I believe are odd behavior. Basically it almost sounds as though the sub is playing sounds higher than what it is supposed to (ie the higher frequencies) and not limited to just the low ones. By no means do I think it's playing all but it just sounds odd. Wondering if something is wrong, and what I should do to resolve?
Any help would be appreciated.
raschkec is offline
post #2 of 2 Old 12-06-2012, 06:49 AM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1809
Perhaps Audyssey has set the crossover(s) too high. What is it (are they) set to?
eljaycanuck is offline
