Subwoofer Ownership – Your Path to Satisfaction - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 07-18-2013, 09:47 PM
jlpowell84's Avatar
Quoted: 1614 Post(s)
Liked: 712
If you had to, based on your experience, List the top 5 quality/perfprmance drivers currently available on the market.
jlpowell84 is offline
Old 07-18-2013, 10:35 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
That's open to too much speculation. With the exception of a handful on here, most people have never had more than 1 or 2 premium subs available at one time; let alone 5. If you've only owned one or two; how do you know they would be considered a top 5 driver?
Quality and performance aren't necessarily synonymous with each other. I've owned some quality drivers that I wouldn't consider stellar performers; and I've owned some that performed, but weren't high on quality.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 07-18-2013, 10:42 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
Well based on specs and some measurements I would say
RE XXX
LMS 5400
FTW-21
UXL-18
So far but there are many drivers that can have the same type of performance in multiples. These are if you need one or two subs.
Marantz 7702 Atmos
MKtheater is online now
Old 07-19-2013, 06:17 AM
enterthedragon's Avatar
Anyone ever try an MTX Jackhammer?
All hype.
I bet this would out perform a Jackhammer.
http://youtu.be/49mpKRrE_7Q
enterthedragon is offline
Old 07-19-2013, 09:10 AM
jlpowell84's Avatar
Liked: 712
Old 07-19-2013, 09:11 AM
jlpowell84's Avatar
Liked: 712
RE XXX
LMS 5400
FTW-21
UXL-18
Where would you say the Captivator/OS driver fits in there?
Old 07-19-2013, 09:15 AM
jlpowell84's Avatar
Liked: 712
A dual config that looks like a cap s2 except the RE XXX drivers would be beastly. Prob cost not much short of them either
Old 07-19-2013, 09:26 AM
MKtheater's Avatar
Liked: 1122
Just a guess until they get tested. Based on specs it would be below the rest because it has less displacement than the rest. The RE XXX was tested in a box much too small for it and still did excellent. It would be much better in a bigger box.
Marantz 7702 Atmos
Old 07-19-2013, 10:02 AM
jlpowell84's Avatar
Liked: 712
Just guessing on a whim...what do you think 2 of these bad boys in a rightfully sized box would do? 8ft for 2 according to RE's site.
Old 07-19-2013, 10:20 AM
No way the XXX could fit in a box remotely close to the same size as the Cap S2. I want to say the basket/magnet depth is like +13" deep.
Do it...
http://www.avsforum.com/t/1448650/fs-pair-of-re-xxx18s-final-price-drop/0_100
Old 07-19-2013, 10:36 AM
MKtheater's Avatar
Liked: 1122
The RE XXX is a beast in the right size box, 8 cubic feet is good, for one of them! These are the ultimate IB drivers with 13 liters of displacement.
Marantz 7702 Atmos
Old 07-19-2013, 10:38 AM
jlpowell84's Avatar
Liked: 712
Do it...
The are 14 and change...was just on the website. It recommends 4 cubic ft ideally for one driver
Old 07-19-2013, 10:48 AM
MKtheater's Avatar
Liked: 1122
That is for a car. 4 cubic feet is good for a LMS 5400, this beast needs 8 cubic feet. Just ask the guys that own and have measured them.
Marantz 7702 Atmos
Old 07-19-2013, 10:57 AM
jlpowell84's Avatar
Liked: 712
I see. What exactly is an IB? I googled it. Looks like subs facing the opposite way?
Old 07-19-2013, 10:58 AM
jlpowell84's Avatar
Liked: 712
Damn, I could pick up those from beast right now
How do these subs fair with SQ? It is an important factor for me. I have read these subs are beasts and built for high output but also have good SQ
Old 07-19-2013, 11:04 AM
MKtheater's Avatar
Liked: 1122
As good as the others. The others will have more midbass than these.
Marantz 7702 Atmos
Old 07-19-2013, 11:14 AM
jlpowell84's Avatar
Liked: 712
But they will provide enough mid bass right? 2 or 4 of these would cover it all?
Old 07-19-2013, 11:18 AM
Quoted: 360 Post(s)
Liked: 437
Infinite baffle. In a nutshell; you are using an opposing rooms space as the box. No coloration of sound amongst other benefits.
Old 07-19-2013, 11:23 AM
jlpowell84's Avatar
Liked: 712
So I would build the box and mount the subs with the magnet out? Can the be mounted normal?
Forgive all my questions. I'm like that new guy at a job who just doesn't know all the terminology yet smile.gif
Old 07-19-2013, 11:55 AM
MKtheater's Avatar
Liked: 1122
Enough depends on your goals but yes they will have lots of Midbass. Look at the ported XXX to get an idea of Midbass. An IB is like a sealed sub but with a huge enclosure and less power where the sealed sub has a small enclosure and lots of power. The IB uses a room like an attic or crawl space for the box so you can put a line array on your walls with the backs facing in the other room for a very simple design. The bad is that room will get the same bass wave so if not contained will rattle that room as much as the intended room. That is the only reason I have not gone IB yet, I have my bass in my sealed room.
Marantz 7702 Atmos
Old 07-19-2013, 12:13 PM
jlpowell84's Avatar
Liked: 712
Well considering I don't own a home yet I would be building a sealed enclosure
Old 07-19-2013, 12:28 PM
jlpowell84's Avatar
Liked: 712
How would a 12.2 cubic ft enclosure do with two of these bad boys? 48x22x20.
Old 07-19-2013, 01:02 PM
That would be pretty gangster...
Tell you what... 54mm xmax sure would be fun to look at! $1000 for a pair is one hell of a deal!
These subs are VERY power hungry. VERY VERY power hungry.
Old 07-19-2013, 10:12 PM
jlpowell84's Avatar
Liked: 712
How would this amp do with 2 RE XXX's?
http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-7986
Also if they are 2 Ohm subs, would I just wire them separately to their own binding posts? So have two sets of binding posts on the box. And opinions on a 12.2 ft3 enclosure. Should I shoot for a little more air?
Old 07-20-2013, 09:07 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Maybe more like a Lab Gruppen 14000 (or clone)....at least that was what I was thinking when he said very power hungry....
lovinthehd is offline
Old 07-20-2013, 10:10 AM
jlpowell84's Avatar
Liked: 712
Yea I had them cross my mind. I hear they are really costs effective but can be problematic. There is just a lot I don't know with DIY, not sure if it's the best route at this point. As in I have enough money from gear sales and could begin moving forward in a DIY sub build slowly. DECISIONS! I was thinking those Peavey amps because it says they put out 3700 watts a channel 2 ohm. The 2 RE XXX beast has are 2 ohm...Hmm maybe not, I just ran through the numbers and with the sensitivity rating (86.2) we are at 4096 watts at 121 db (2048 at 119) but that would be good right? The enclosure and room gain will add how many db's?
Also, how would these subs do with decay time, distortion, etc?
But this is a sexy pic!
Old 07-20-2013, 04:07 PM
Haha.. One channel per voice coil. Yeah, that'll do....
Old 07-20-2013, 04:42 PM
jlpowell84's Avatar
Liked: 712
^Yeah, I'm sure they would max out the amp if one channel per sub. It seems the LG clone amp is the only feasible way to go with these.
Old 07-20-2013, 04:45 PM
jlpowell84's Avatar
Liked: 712
Well boys, I'm flying out to Oahu in a few hours. Lata!
Old 07-20-2013, 08:04 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
The RE XXX 18 is a monster, here is the pic to prove it next to Dayton RS 18" and Maelstrom-X 18" on either side of the King:
The reports of needing big power are true, it would help if you lived next to a nuclear power plant biggrin.gif The XXX lives in low bass land but don't expect too much mid-bass, better have big mains to provide that. The LMS Ultra may be a better all around choice unless your willing to go whole hog with the XXX. If you have space then multiple SI or Dayton RS 18" subs are a good choice as well.
mjaudio is online now
Dayton Audio Dvc385 88 15 Dvc Series Subwoofer , Klipsch Rw 12d 12 Subwoofer Each , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Jtr
