Sub for movies in large/unusual room - yeah another one - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-10-2012, 08:23 AM - Thread Starter
xyzzy_nc's Avatar
Looking for some ideas on improving the bass in this room. The room itself is 13'x16'x20' and also opens to a loft, dining room, and upstairs hallway so I've got lots of air. All windows have shutters. I'm trying to avoid becoming an audiophile so I don't need sonic perfection. Just looking for more feeling from the bass and some visceral chest thumping goodness. The only listening area to optimize for is the recliner shown. Current sub is a REL R-505 (500W RMS). My placement options are on that wall and on the wall underneath the stairs. I need to stay around 20" depth for that front wall and don't want to block the in-wall speakers. For under the stairs, I could do around 24" depth so side firing might be good if I need a large one. My receiver is an Integra DTR40.4 and has two subwoofer outputs. I'd like the sub to be somewhat attractive and fit into the room, but that's flexible. Looking to spend $1500-2500 including everything. I don't have any gear to do sound measurements, although I could perhaps borrow something as I know placement is key here.
xyzzy_nc is offline
post #2 of 6 Old 12-10-2012, 08:40 AM
BeeMan458's Avatar
Liked: 813
Based on you above specs, I'd go with a pair of Hsu, ULS-15's.
I'd also consider investing in a DSPeaker, Anti-Mode, 8033S II, to help balance the two subs to the room acoustics. No matter if you get black or Rosenut, the total delivered outlay for the pair of subs would be under $2,500.00. The Anti-Mode, 8033S II would add an additional $450.00.
I purchased the Anti-Mode from Creative Sound Solutions.
BeeMan458 is offline
post #3 of 6 Old 12-10-2012, 09:14 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
But your depth requirement is a tough one for the front wall.
Maybe start with one of these and potentially add a second:
http://www.powersoundaudio.com/collections/power-x/products/xv15
Or a pair of these:
http://www.outlawaudio.com/products/lfm1plus.html
Another option is the cylinder subs from SVS possibly:
ack_bk is offline
post #4 of 6 Old 12-10-2012, 12:02 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
You have a nice budget, and you are going to need it because that is a very large space. The good news is you only have to worry about one listening position, and that makes matters simple. The subwoofers I would consider in your criteria are the aforementioned Hsu ULS-15 pair, a pair of Rythmik F15HP, or one of the subs from Seaton Sound. You have a nice open space right next to your reclining chair, and one thing you can do to get a nice punchy feeling is near-field placement, which is placing a sub very close to your listening position like an endtable in your situation. You might be able to save some money and get a decent sub for that placement, one I can recommend for that role is the Hsu VTF3 mk4. Place it so that side-firing woofer is blasting right into your seat, and you may get what you are looking for and save some money at the same time.
shadyJ is offline
post #5 of 6 Old 12-10-2012, 12:13 PM
Reefdvr27's Avatar
Quoted: 1566 Post(s)
Liked: 1045
Power Sound Audio Dual XV-15's. Be about $1400 shipped! Tom and Jim and two of the best in the business!
Reefdvr27 is offline
post #6 of 6 Old 12-10-2012, 08:44 PM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1826
My placement options are on that wall and on the wall underneath the stairs. I need to stay around 20" depth for that front wall and don't want to block the in-wall speakers. For under the stairs, I could do around 24" depth ... Looking to spend $1500-2500 including everything.
Front wall:
PSA XS30 ($1,049,shipped):
- dual 15" drivers
- 725W RMS amp
- 19-200Hz +/-3dB
- 23.5” (w) x 18" (d) x 22.5" (h) (include grills and feet)
Under stairs:
Rythmik FV15HP ($1,274 + shipping, or $1,499 + shipping for piano black finish)
- 15" driver
- 600W RMS amp w/ servo control
- 14-90 Hz (-2 dB @ 14 Hz) with LINE IN inputs
- Multi-tune - 18hz (2 port) and 12hz (1 port)
- 18" (w) x 24" (h) x 24" (d) (26" (d) with grille and heatsink)
eljaycanuck is offline
