What is the best subwoofer I can get for a "Energy Take Classic 5.0" for under $200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-12-2012, 11:40 PM - Thread Starter
mariusz47's Avatar
I am looking for the best subwoofer to match the Energy Take 5 Pack
My room's dimensions are 18*17*9
Which one of these would be the better choice?
Or is there a better sub that I can buy for under $200 for the energy take classic 5.0 speakers?
Is there a big enough different between the Dayton and the PW505 or BICF12, to spend the extra $70-$80?
Lastly, are both of the following receivers compatible with the speakers and do they provide the same audio and video quality? If not, what would you recommend in a similar price range?
Thank you guys
mariusz47 is offline
post #2 of 3 Old 12-13-2012, 01:27 PM
batpig's Avatar
Quoted: 3728 Post(s)
Liked: 3606
Any receiver is "compatible" with those speakers. That said, avoid the 15xx Denon models and go with the 16xx at the minimum so you get Audyssey auto setup and room EQ processing. It will make a BIG difference in calibrating your system, especially for a novice.
If the Denon 1612 for $200 works for your budget, go with it.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #3 of 3 Old 12-13-2012, 01:56 PM - Thread Starter
mariusz47's Avatar
Oh, ok. Thanks for the info.
