KLIPSH RW12D SETTINGS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-13-2012, 06:33 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
hi have a klipsh rw 12 and watch mostly movies with it. which setting should i have it on flat punch or depth.i read some people say for movies use depth others say use flat setting. which do you think is best
destiny 21 is offline
post #2 of 8 Old 12-13-2012, 07:17 AM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1911
Most seem to use punch for music and depth for movies.
Licence to Kill
Bond 007 is online now
post #3 of 8 Old 12-13-2012, 08:29 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
READ THIS http://www.avsforum.com/t/1390563/klipsch-rw-12d-omnimic-frequency-response-graphs.
It seems like DEPTH might be the best setting, as its the Flattest response.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #4 of 8 Old 12-13-2012, 02:42 PM
pghflyer's Avatar
I just got this and wanted to run the Audyssey on my Denon AVR-888. The manual says to defeat the volume. Does this really mean that I should completely reduce the volume on the digital display?
pghflyer is offline
post #5 of 8 Old 12-13-2012, 04:02 PM
Bond 007's Avatar
Liked: 1911
Set volume to 0 to start.
Licence to Kill
post #6 of 8 Old 12-15-2012, 08:56 AM
pghflyer's Avatar
Thanks much Mr. Bond
pghflyer is offline
post #7 of 8 Old 01-15-2013, 03:03 PM
Mikeclough24's Avatar
Quoted: 72 Post(s)
Liked: 29
Would that be the same for my pioneer vsx MCACC setup? Turning the volume down to zero on my klipsch rw12d? I turned it down to about 25% when I ran it.
Mike Clough #24
Mikeclough24 is offline
post #8 of 8 Old 01-15-2013, 07:04 PM
Bond 007's Avatar
Liked: 1911
Yes. The rw does not display %. Please be specific for the best help. Start at 0.
Licence to Kill
Klipsch Rw 12d 12 Subwoofer Each
