Rw12D or bic f12.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-14-2012, 06:38 PM - Thread Starter
Sucio's Avatar
I currently own the f12 and just purchased rw12d... Can I use them both or would I be better off just using the rw12d.
Sucio is online now
post #2 of 5 Old 12-14-2012, 07:40 PM
LCDeez's Avatar
Obviously u can use both....but I wouldn't because they prob sound really different
LCDeez is offline
post #3 of 5 Old 12-14-2012, 08:28 PM - Thread Starter
Sucio's Avatar
So, I would be better off using only one sub?
Sucio is online now
post #4 of 5 Old 12-14-2012, 08:41 PM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
Depends on how well you can tweak them individually and placement as well as other factors. I am in exactly the same situation. I live in an apt and recently got the RW. I was going to try to use them both but as much as I tried the F12 just made the RW sound bad. Sometimes I will use both for movies just to kind of fill the room a little better (the RW really doesnt need the help) but for music I turn the F12 off.
Licence to Kill
Bond 007 is offline
post #5 of 5 Old 12-15-2012, 10:28 AM
Archaea's Avatar
Quoted: 2846 Post(s)
Liked: 2427
The RW-12D has a lower port tune. Running both subs will eliminate the lower frequency reproduction ability of the RW-12D, because the BIC F12 will basically be running out of phase below its port tune - which negates the RW-12D's sound at those frequencies.
So yes you'll get more volume with two, but you'll actually have less low frequency sound than if you ran the RW-12D alone. Meaning say about 22-32hz will be negated on the RW-12D --- which really just negates the reason to have bought an RW-12D in the first place. Sell the F12 and buy another RW-12D if you want more spl.
Archaea is online now
Klipsch Rw 12d 12 Subwoofer Each
