REL T7 Subwoofer Test Up at Sound&Vision - AVS Forum | Home Theater Discussions And Reviews
Old 12-24-2012, 01:02 PM - Thread Starter
spyboy's Avatar
Liked: 47
Brent Butterworth tested the Rel T7 in the January 2013 issue of Sound&Vision magazine. Check to see if its up on the web.
The Rel T7 has an 8 inch driver and a 10 inch passive radiator. With the REL T7 Sumiko and REL recommend connecting your front left and right amp channelsto the T-7's speaker level inputs, instead or in addition to using the sub's line level inputs with your surround processor's subwoofer output.
Sound quality is certainly good, however, for $1,000 I would be looking at something from Rythmik. Quite small and rather light at 34 pounds.
I know there is a REL following. For them the T7 makes sense.
Happy Holidays
The review does not appear to be online @Sounf&Vision yet.
One finding is that using CEA 2010 guidelines the Ultra Low Bass measured 97.7 db from 20-31.5Hz. For $1,000 I think there is more to be had. I would start by comparing the T7 to Rythmik.
spyboy is offline
Old 12-26-2012, 03:10 PM
JA Fant's Avatar
Quoted: 233 Post(s)
Liked: 324
Thanks! for sharing spyboy. Big fan of REL here. I have auditioned the 'Britania' series as well as this newer 'T' series.
JA Fant is offline
