Sunfire SDS-10 worth buying? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2012, 10:03 AM - Thread Starter
astrapogiannos's Avatar
I'm between buying Sunfire SDS-10 or Earthquake S-10.I believe most of you have heard the Sunfire so can you tell me your impressions so far? Is it worth 430€ ? I need it only for playing music,tracks with very low and continuously bass smile.gif
From the other hand,here's a link to Earthquake S-10's manual
Thanks for your time!
astrapogiannos is offline
post #2 of 4 Old 12-30-2012, 02:19 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Do you have some sort of space constraint or something that requires you to have such a small footprint? You can do better if size isn't a restriction.
stormwind13 is offline
post #3 of 4 Old 12-31-2012, 01:07 AM
John4721's Avatar
I owned the bigger Sunfire SDS-12 for about a week and a half. It was a good sub, but, according to sound&vision it didn't hit the ultra low notes with much authority and I'd tend to agree. I returned it and went with an SVS SB12-NSD. For my room size at least and my ears, it was a significant upgrade in terms of both power and sound quality across the board for not much more money. SVS does have some European dealers and a new line of 10" driver subs that should be in the price range with the SDS-10. Might be worthy of consideration, though, I don't know about the voltage differences and availability.
John4721 is offline
post #4 of 4 Old 01-02-2013, 09:33 AM
Quoted: 60 Post(s)
Liked: 96
if you are comfortable with diy, you can build a lilmike cinema f20 in that price range which would decimate anything you have looked at so far. It's much larger though.
