Trouble connecting sub to my A/V amp - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 07:08 PM - Thread Starter
Nav117's Avatar
I have a fiarly old Pioneer VSA-E07 amp and was wondering how I would connect my Sony subwoofer to it. The sony subwoofer runs on a coaxial cable, but I don't think I can use this on my amp.
Heres the connections for the amp;
Any ideas and advice on what type of sub I could run off this amp would be highly appreciated smile.gif
*Same thread posted in A/V amp section
Nav117 is offline
Old 12-30-2012, 11:53 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Use the subwoofer pre-out (sw) in the upper left area of the avr.
Nav117 likes this.
lovinthehd is offline
Old 12-31-2012, 03:54 AM - Thread Starter
Nav117's Avatar
I've tried that it seems thats a RCA connection and the sub uses coaxial cable. Any more suggestions? Thanks
Nav117 is offline
Old 12-31-2012, 05:46 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
... it seems thats a RCA connection and the sub uses coaxial cable. Any more suggestions?
Yes: Post a pic of the sub's plate amp.
Nav117 likes this.
eljaycanuck is offline
Old 12-31-2012, 06:01 AM - Thread Starter
Nav117's Avatar
Here it is;
I've tried connecting it to the preout subwoofer connections with no luck, using a coaxial cable. Maybe I have the change some settings on the amp?
I was using this sub in my older Sony setup with a coaxial cable into the sony reciever, a picture of that'
Nav117 is offline
Old 12-31-2012, 06:24 AM
bfreedma's Avatar
Liked: 51
Both connections look standard to me. Do you have your speakers set to "small" in the AVR?
Nav117 likes this.
bfreedma is offline
Old 12-31-2012, 07:00 AM - Thread Starter
Nav117's Avatar
I'm new to the amp so I'm not sure! Trying to check that now but can't find a setting like that!
Maybe I shouldn't be using a coaxial cable for this amp?
Nav117 is offline
Old 12-31-2012, 07:03 AM
Liked: 1800
I've seen it happen before where someone has accidentally connected the cable to the pre-input terminal (circled in red) rather than the pre-output terminal (circled in green). So, just to confirm, you do have the cable connected to the pre-output terminal?
If 'yes', have you tried another cable just to make sure there's not a problem with the one you're using?
Nav117 likes this.
Old 12-31-2012, 07:06 AM
Liked: 1800
If it's got RCA connectors on both ends, that's what you should be using.
Nav117 likes this.
Old 12-31-2012, 07:55 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Coaxial refers to the construction of the wire, not the connectors used.
+1.
Nav117 likes this.
Bill Fitzmaurice is offline
Old 12-31-2012, 08:05 AM - Thread Starter
Nav117's Avatar
Yeh I tried both of them just to be safe, but not with any luck. The cable did work when I was using it for my other amp so I'm 90% sure it is, however will double check that.
It does have RCA to RCA connection but has "digital" written on the connectors, which made me think it was a coaxial digital cable. Might order another RCA to RCA to see if that might work?
Nav117 is offline
Old 12-31-2012, 08:12 AM
Liked: 4631
That's meaningless advertising piffle. Wire is wire. Insert the cable into the sub amp, turn it on, put your finger on the center conductor at the other end of the cable. The sub should hum. If it doesn't the cable may be bad. If it does the cable is good and the problem lies either in the AVR or in how you have it hooked up.
Nav117 likes this.
Old 12-31-2012, 08:13 AM
Liked: 1800
It is, in the sense that it's not an optical digital cable. But coaxial digital is a cooler-sounding way of saying "wire with RCA connectors on both ends".
Save some time and money by using that cable for a left or right analogue connection from a source (DVD or BD player) to the AVR. If you get audio through the channel that cable is on, then the cable's fine.
Nav117 likes this.
Old 12-31-2012, 08:35 AM - Thread Starter
Nav117's Avatar
Turns out the front speakers had to be turned into small ones as bfreedma suggested. Sounding great!
Nav117 is offline
Old 12-31-2012, 08:46 AM
Liked: 4631
Old 12-31-2012, 09:15 AM
whoaru99's Avatar
Liked: 69
Huh? I was under the impression it typically was the man way to dive in without RTFM.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 12-31-2012, 09:22 AM
bfreedma's Avatar
Liked: 51
Originally Posted by whoaru99 View Post
Huh? I was under the impression it typically was the man way to dive in without RTFM. smile.gif
bfreedma is offline
Old 12-31-2012, 09:23 AM
whoaru99's Avatar
Liked: 69
whoaru99 is offline
