Possible to connect three/four subwoofers instead of two? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-31-2012, 06:46 PM - Thread Starter
Rayscordova's Avatar
I have a Pioneer SC-63 AVR and two Definitive Technology BP-8040ST, one CS-8060HD, and a Supercube 2000.
The center channel, both R/L towers and the supercube all have LFE inputs buy my Pioneer receiver only has two LFE outs.
Is there anyway I can hook all four up?
Thanks in advance for responses.
Rayscordova is offline
post #2 of 7 Old 01-01-2013, 06:02 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
You can pick up rca splitters at radio shack or monoprice.com. Some individuals in this forum run 4 subwoofers off one LFE out on their AVRs.
wwinkler is online now
post #3 of 7 Old 01-02-2013, 10:38 AM - Thread Starter
would this cause a problem of not getting enough signal to the sub woofers and cause signal loss
post #4 of 7 Old 01-02-2013, 10:40 AM
wingnut4772's Avatar
Liked: 29
I run 5 with no issues. Two LFE out on my Anthem.
Kaboom.
wingnut4772 is offline
post #5 of 7 Old 01-02-2013, 12:08 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
AFAIK, the only potential issue with splitters is that the receiver's output sees a lower input impedance because the multiple amp inputs are connected in parallel. But again AFAIK, the primary potential issue is high frequency roll off, and thesea are subs we're talking about, so if the output were "massively" down by 3 dB at 10 KHZ, it's so far out of the relevant passband as not to matter.
Lots of folks here do it. The pre is only swinging a volt or 2, and even if you've pulled the input impedance all the way down to 250 ohms, that's only .008 amps of current, or a total of 0.016 watts . . .
wingnut4772 likes this.
JHAz is offline
post #6 of 7 Old 01-02-2013, 06:38 PM - Thread Starter
is it possbiel to connect the center channel and the front right and left spekaers to the pre outs and still get the correct subwoofer sounds?
post #7 of 7 Old 01-02-2013, 07:10 PM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
First off I would highly discourage using the "subwoofer" in your center speaker. It is not a true subwoofer but just a woofer that is used to extend the center frequency down to about 40Hz (and that's on a good day). With your current receivers universal crossover for all channels I would suggest hooking all speakers up using speaker wire only hook the sub using the sub preout using RCA jacks and set the pioneers crossover to 40Hz. Give that a try. If you notice distortion during bass heavy movies raise the crossover to 60Hz. DefTechs built in "subs" are not true subwoofers and are best described as "mid bass" subs meaning they work best at 40-80Hz anything lower and the bass becomes boomy and distorted. I know I have BP7001's and when set to Large the bass sounds horrible. Set to 40Hz and the bass is very tight loud and well controlled. I let my SVS handle everything below 40Hz.
UofAZ1 is offline
