new sub for 800-1500 $ sugetions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-01-2013, 03:12 PM - Thread Starter
pavteff's Avatar
Quoted: 22 Post(s)
I have been looking at the velodyne eq 15max and the optima 12. Listen to music but mostly for movies. Would appreciate any thoughts you might have.
pavteff is offline
post #2 of 12 Old 01-01-2013, 03:15 PM
XStanleyX's Avatar
Liked: 1269
XStanleyX is offline
post #3 of 12 Old 01-01-2013, 03:27 PM
blackangst's Avatar
Quoted: 116 Post(s)
Liked: 102
Dual Hsu VTF3MK4's.
My system: Yamaha RX-A3060, Emotiva XPA-2, Salk Song3, Salk Songcenter RT, Polk FXiA6, Rythmik FV15HP, Intel i7 HTPC running JRiver Media Center
blackangst is offline
post #4 of 12 Old 01-01-2013, 03:29 PM - Thread Starter
pavteff's Avatar
Quoted: 22 Post(s)
I forgot to put the room size in. . About 3200 cu feet. It does have openings to the kitchen on one side and the family room on the other.
pavteff is offline
post #5 of 12 Old 01-01-2013, 03:41 PM
vraxoin's Avatar
Quoted: 13 Post(s)
Liked: 36
Does subwoofer size matter? Do you have space for more than one sub? Do you have much placement flexibility? Are you looking for high output in that space or are you more of a moderate listener? Do you already have some form of subwoofer EQ?
vraxoin is offline
post #6 of 12 Old 01-01-2013, 03:54 PM - Thread Starter
pavteff's Avatar
Quoted: 22 Post(s)
Would rather try a larger sub. right now I have a 10" boston and it just doesn't go low enough and when it does it distorts. One sub only and I do have some placement flexibility. I have an eq with my onkyo sr875 but don't really know how much it effects the sub. Would like somthing that does well with music also. Listen to a lot of classical and jazz
pavteff is offline
post #7 of 12 Old 01-01-2013, 04:09 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
Rythmik FV15HP fits in that budget....
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
post #8 of 12 Old 01-01-2013, 04:13 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
It's hard to beat a single FV15HP with the 550watt amp option for under $1200 plus shipping! I ended up going with PSA XS30s just to try them but the FV15HP was my second choice.
jbrown15 is offline
post #9 of 12 Old 01-01-2013, 04:19 PM
XStanleyX's Avatar
Liked: 1269
+1
That was my choice after a month of research. Any of the subs over a grand will make you happy though.
With the 550 watt amp it comes to $1236 which includes shipping.
post #10 of 12 Old 01-01-2013, 05:39 PM - Thread Starter
pavteff's Avatar
Quoted: 22 Post(s)
People have suggested HSU and Rythmyk but have have said nothing about the velodyne optima12 or eq15max. jUST WONDERING WHY THAT MAY BE?
pavteff is offline
post #11 of 12 Old 01-01-2013, 05:41 PM - Thread Starter
pavteff's Avatar
Quoted: 22 Post(s)
sorry just acidently pressed the caps button
pavteff is offline
post #12 of 12 Old 01-05-2013, 03:29 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
The above choices will suit your needs. Dual OUTLAW LFM-EX or Dual EPIK EMPIRE when they start to ship again would be great choices. This would as well HSU VTF-15
good luck
ratm is offline
