NXG Technology NX-BAS-500 12" - Page 5 - AVS Forum
 3Likes
post #121 of 132 Old 07-05-2014, 08:47 PM
Bond 007's Avatar
Quoted: 82 Post(s)
Liked: 821
Originally Posted by maestro24 View Post
opinions on the next best sub(s) after the $300 range that will out perform the nxg?
svs pb1000
Maestro24 likes this.
Bond 007 is online now
post #122 of 132 Old 07-05-2014, 08:55 PM
bargugl's Avatar
Quoted: 13 Post(s)
Originally Posted by Maestro24 View Post
Opinions on the next best sub(s) after the $300 range that will out perform the NXG?
I have not heard them, but based on measurements, I'd put the Hsu STF-2 as the next very modest step up. Then after that is the $500 SVS PB-1000 and possibly the Reaction Audio BPS 212. There's a serious gap of selection right now in between the under $300 category and the $500+ category. There were a few internet direct sub companies that had decent subs there a couple years back, but they have either all gone under or moved out of the category. Also not really any fire sales of higher priced subs from the big brands right now either (like the Klipsch RW-12D/Jamo 650/Energy S10.3 from a bit back).
bargugl is offline
post #123 of 132 Old 07-05-2014, 09:59 PM
Gmash's Avatar
Quoted: 20 Post(s)
Liked: 69
$500-Reaction BPS-212, SVS PB-1000
$600-Hsu VTF-2 Mk 4, Rythmik LV-12R
Gmash is offline
post #124 of 132 Old 07-06-2014, 01:46 AM
collven's Avatar
Jim, I have a question about your procedure when you reviewed this. I received mine yesterday from Radio Shack and will probably be setting it up Monday, after letting it break in a bit. When you set your review unit up, where did you set the volume on the sub itself?
My receiver doesn't have Audyssey or anything, so I will set the levels manually. Everywhere I look, people seem to have different opinions on where the subwoofer's volume should be set. I've read halfway, 3/4 or even all the way up. Does it depend on the receiver? Basically whatever puts me at 0 or even -1 or -2 for the sub level in the setup?
collven is offline
post #125 of 132 Old 07-06-2014, 06:43 AM
James004's Avatar
Are there any subs in or near this price range that have parametric EQ?
James004 is online now
post #126 of 132 Old 07-06-2014, 07:14 AM
JimWilson's Avatar
Quoted: 46 Post(s)
Liked: 307
It depends on a multitude of factors; distance from the sub, size of the room, capability of your mains, personal preference for loudness, sensitivity of the gain knob, etc. In general though my process is to tune by ear until I feel the unit is broken in, just to get a sense for its performance. After x number of hours (x being determined by what the manufacturer suggests, or about 15 if they don't specify) I'll set the gain at 50% and run Audyssey. If Audyssey comes back with a -12 I'll drop the gain some and run it again. Repeat until Audyssey is happy, at which point I'll usually adjust the gain up some because I've often found it likes the sound to be a bit weaker then I do.
Historically that process has meant things are set at 40%-60% gain on the sub amp and 0dB as the output level from my AVR. The AVR level is more critical for me than the sub gain; I would much prefer to boost the output by way of the subwoofers amplifier than the input level. The latter could introduce additional signal noise, so I tend toward keeping the input level lower and the subwoofers gains higher if I need to make adjustments. I don't recall ever having to go as high as 3/4th's though, but that would be my absolute limit regardless. I would never even consider max - were that necessary I would add a second subwoofer or get a larger one.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is online now
post #127 of 132 Old 07-06-2014, 10:21 AM
collven's Avatar
Thanks Jim. Sounds pretty much like I planned on doing it.
collven is offline
post #128 of 132 Old 07-07-2014, 12:42 PM
Quoted: 12 Post(s)
Liked: 0
How does this compare to the BIC PL-200?
Warner2Bruce is offline
post #129 of 132 Old 07-07-2014, 02:35 PM
JimWilson's Avatar
Quoted: 46 Post(s)
Liked: 307
I won't be able to compare it with the PL-200, but in a few weeks I can with the H-100...
post #130 of 132 Old 07-08-2014, 03:20 PM
James004's Avatar
I am eagerly waiting for that. But then the NXG will be out of stock again! I am still deabating on saving my pennies for an HUS or SVS. But getting my wife to agree to that will be a hard sell. The NXG or H-100 would not be too difficult.
James
post #131 of 132 Old 07-08-2014, 06:00 PM
laserjock II's Avatar
Liked: 46
James
Just give the NXG a go and be done.
laserjock II is online now
post #132 of 132 Old 07-08-2014, 06:03 PM
Bond 007's Avatar
Quoted: 82 Post(s)
Liked: 821
+1
No, Mr. Bond. I expect you to die!
User Tag List
