NXG Technology NX-BAS-500 12" - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #151 of 228 Old 07-25-2014, 01:15 AM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
Originally Posted by BigLouis1971 View Post
Is the NXG Technology NX-BAS-500 12" more accurate than the Dayton Audio SUB-1200?
From my perspective it was.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #152 of 228 Old 07-25-2014, 01:40 AM
BigLouis1971's Avatar
Quoted: 27 Post(s)
Why do you say it was? Did the NXG got worse or the Dayton Audio better?
BigLouis1971 is offline
post #153 of 228 Old 07-25-2014, 04:32 AM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
Probably because it is. Why would it need to be any reason like that?
Bond 007 is online now
post #154 of 228 Old 07-25-2014, 04:44 AM
Quoted: 27 Post(s)
I don't understand your point. When you measure accuracy why one sub can't be more accurate than another? If that isn't a reason that makes sense then which one does makes sense? If one sub isn't more accurate than another then why are so many different brands and prices? I'm just asking a simple question because the NXG doubles the Dayton in price. I demand that it also doubles the accuracy. If it doesn't then there's no point to be more expensive.
post #155 of 228 Old 07-25-2014, 04:53 AM
Bond 007's Avatar
Liked: 1907
The NXG is more accurate from the factory. There is no transformation taking place.
As far as I know its not something you can measure. You simply hear it. Expecting twice the accuracy for twice the price is unrealistic.
post #156 of 228 Old 07-25-2014, 05:22 AM
Quoted: 27 Post(s)
Have you heard both of them so you can compare them and tell me the differences in more detail?
post #157 of 228 Old 07-25-2014, 05:51 AM
Bond 007's Avatar
Liked: 1907
No
post #158 of 228 Old 07-25-2014, 08:04 AM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 142
If the confusion is over the word "was", it's because he didn't keep either sub, Jim wrote the reviews for both.
http://www.hometheatershack.com/foru...er-review.html
Gmash is offline
post #159 of 228 Old 07-25-2014, 10:20 AM
Quoted: 27 Post(s)
Now that makes sense. It was more accurate because he don't have it anymore. I didn't knew that fact because I found this forum just a few months ago and I don't come here too often. So this resulted in crucial info to decide for the NXG over the Dayton. Thanks to everybody for your attention.
post #160 of 228 Old 07-25-2014, 10:27 AM
JimWilson's Avatar
Liked: 1560
Now I'm confused. What just happened?
post #161 of 228 Old 07-26-2014, 03:01 PM
Liked: 0
looking for help to setup my receiver and sub settings
I m newbie to home theater stuff. Find my system details below.
Klipsh Quintet V
Yamha RX V577
NXG-NAS 500
Need help in setting up the crossover and other settings in my receiver.
My room size is 11'× 16.2'
I hooked the receivers subwoofer preout to NXG-NAS 500's R or LFE. Also based on discussion in this thread, set my crossover to Max in Subwoofer and sound to 3/4 intially and ran the YPA0. Got the W-1 out of phase and W-3 Level error from YPA0 which i ignored.
Find the below settings which YPAO recommended from my reciever.
Front,center and surround set to Large
Crossover : 60HZ
Front L :0.0dB
Front R : 0.0dB
Center : +1.5dB
Surround L +8.5dB
Surround R ; +4.0dB
Subwoofer : -10.00 dB
I couldnt hear any bass from reciever. so i changed the front, center and surround speaker sizes to small and cross over settings to 120HZ in receiver as recommended by Klipsh, also increased the subwoofer level to 0.0dB from -10.00dB in receiver but still i feel some kind of boomy sound in some music videos.
Please help me in setting up the cross over and other settings. I listen to both music and movie.
Appreciate your help in advance.
Htrnewbie is offline
post #162 of 228 Old 07-26-2014, 03:08 PM
Bond 007's Avatar
Liked: 1907
Klipsh Quintet V
Yamha RX V577
NXG-NAS 500
Crossover : 60HZ
Front L :0.0dB
Front R : 0.0dB
Center : +1.5dB
Surround L +8.5dB
Surround R ; +4.0dB
You have done everything right. Except you need to rerun YPAO until it sets the sub to around -3. -10 is the maximum displayed so it may actually be -16 or something.
After that set all speakers to Small. Xover to 120. And tweak the sub volume AT THE SUB.
The boominess may also be due to placement of the sub. Have you tried moving it around?
post #163 of 228 Old 07-27-2014, 05:35 PM
Liked: 0
Thanks for your input.
I ran the YPAO so many times, the best it can come up with is -5dB for Sub and even for that i have to reduce the volume in Sub less than 3. YPAO came up with the below recommendations
Front L :0.0dB
Front R ; +2.0dB
Center : +0.5dB
Surround L + +5.0dB
Surrond R : +6.0dB
Sub : -5.0dB
I tweaked the volume after this in sub but still i am not getting good music listening experience. I moved the sub around but still im getting the boominess. Is there anything i need to do?
Appreciate your help.
post #164 of 228 Old 08-01-2014, 02:05 PM
zeez's Avatar
Quoted: 22 Post(s)
He read your statement as meaning the NXG was (used to be) more accurate than the Dayton. Due to that, he was trying to understand what changed over time to make it lose accuracy.
zeez is offline
post #165 of 228 Old 08-02-2014, 12:15 PM
gonzo64's Avatar
Originally Posted by gonzo64 View Post
ok i will do that ..thanks.....
Connect to LFE. Set crossover all the way up. Set volume at about halfway. Run Audyssey.
hey bond 007 i did rerun the audyssey and it now set the sub level to a -12.0....i know this isnt right so do i have to rerun again..and will this do anything ..or can i just bump up the level....so what is the normal level i should be looking for ...thanks......my other sub was at a + 5.5
gonzo64 is offline
post #166 of 228 Old 08-02-2014, 01:01 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Yes that is too high. You should run the first chirp of the audysey then check the sub trim. Then adjust the sub gain until you get -3db to -6db and then do the whole mic audysey posotion.
caloyzki is offline
post #167 of 228 Old 08-02-2014, 03:07 PM
gonzo64's Avatar
not getting what you mean here...sub trim...sub gain..ect....sorry....thanks...
gonzo64 is offline
post #168 of 228 Old 08-02-2014, 03:52 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
sub trim is what the result from the audysey. sub gain is where you can adjust the gain knob from the subwoofer.
caloyzki is offline
post #169 of 228 Old 08-02-2014, 03:55 PM
gonzo64's Avatar
couldnt i just maually raise the level from -12.0 to -3.0...or should i lower the volume on the sub and try it again.....what you think
gonzo64 is offline
post #170 of 228 Old 08-16-2014, 08:09 PM
PS3forlife's Avatar
Quoted: 32 Post(s)
Liked: 44
Just to report in. Been punishing my nxg for a good while now. Had heart surgery so everyday it's getting a workout as I have nothing else to do. It is performing flawlessly. Still love and would recommend this sub. Wondering which one Jman would recommend this or the bic he reviewed still very happy with my purchase.
PS3forlife is offline
post #171 of 228 Old 08-16-2014, 08:52 PM
JimWilson's Avatar
Liked: 1560
That very topic came up just a few weeks ago, and this is what I had to say in response.
I'm very sorry to hear about your surgery. I hope you get back on your feet real soon. I'm glad the subwoofer has made the situation a bit more tolerable!
post #172 of 228 Old 09-25-2014, 12:32 PM
ppilot's Avatar
Quoted: 74 Post(s)
Liked: 41
Just wanted to give people an idea of the RMA process as I didn't see much about it in this thread
Have owned this Sub for about a year now and really haven't had any complaints, except for some rattling that started about a month and half ago. Support wasn't super fast at responding and having to ship the sub back on my own dime wasn't exactly cheap, but overall the Customer experience was decent.
They shipped me another Sub within a day of getting my old one, but I haven't had a chance to check the replacement out.
ppilot is offline
post #173 of 228 Old 09-27-2014, 10:34 PM
PS3forlife's Avatar
Quoted: 32 Post(s)
Liked: 44
I had a great response time when my amp took a dump on mine. They responded to email immediatly (except when they were at a show and left no message to the fact on their site also around the time of their warehouse fire) even though they had a fire they shipped me a amp and let me keep the old one that a switch was messed up on. My recommendation is that you only ship them pieces as in the driver itself or amp itself much cheaper that way when you are sure of what it is. They overnighted my replacement amp to me as i had a original amp failure and the second one had a switch messed up. I even alluded to the fact that the first amp failure may have been my fault no questions asked they shipped me one. Great comapny wonderful BUDGET sub that performs well above its pay grade
post #174 of 228 Old 10-07-2014, 02:29 PM
collven's Avatar
Quoted: 17 Post(s)
Well, my sub is dead after 3 months and very little use. At most between 40 and 50 hours of use. Now I'm not getting any power at all. Emailed NXG this morning, waiting for a response.
I bought it from Radio Shack. At least they are willing to ship it to NXG for me so I don't have to pay to ship it myself.
I was happy with it until now. I'm just glad that I'm a pack rat and held on to the box it was shipped in.
collven is offline
post #175 of 228 Old 10-07-2014, 03:38 PM
PS3forlife's Avatar
Quoted: 32 Post(s)
Liked: 44
I have well over 100 hours use on mine still going strong. They let me ship back just the amp as with a little diagnosis that what i determined failed in it. They sent me a new one the day they recieved mine (dead amp was my fault always unplug subwoofer before moving it )
post #176 of 228 Old 12-15-2014, 08:05 AM
James004's Avatar
It looks like the NXG NX-BAS-500 is out of stock again. Not only that but Home Depot and AV Warehouse have no NXG inventory for sale at all. Is something going on? Or did they just run out again? I was ready to pull the trigger on a second BAS-500.
James004 is offline
post #177 of 228 Old 12-15-2014, 12:34 PM
Bond 007's Avatar
Liked: 1907
I sent NXG an email asking just that about a week ago and have gotten no response.
post #178 of 228 Old 12-15-2014, 03:43 PM
JimWilson's Avatar
Liked: 1560
Sigh...
post #179 of 228 Old 12-16-2014, 01:47 PM
laserjock II's Avatar
Quoted: 703 Post(s)
Liked: 378
My email and response from AV House.
"Just wondering if these were going to be available anymore?
I have one and have people asking if they will available in the future.
Can't find them for sale anywhere"
"Hello Chris - Per our distributor they do not have an ETA on this item through the end of this year.
The AV House Team"
laserjock II is online now
post #180 of 228 Old 12-25-2014, 10:14 AM
ppilot's Avatar
Quoted: 74 Post(s)
Liked: 41
The sub woofer they sent me as a replacement for my other one that got went bad just died as well. With The news of them probably not making any more I'm thankful I bought it using American Express so I have additional year warranty on it. Probably going to be increasing my budget for the next subwoofer to between $750-$1000
ppilot is offline
