How do you hook up a powered sub and a non-powered sub? - AVS Forum | Home Theater Discussions And Reviews
Old 01-03-2013, 06:31 AM - Thread Starter
jpl20's Avatar
Hi all, I have a Sony SA-WM20,(pic), hooked up to my Denon AVR-1513, it's a powered 8" sub and I also wanted to hook up a Sony non-powered 12" sub, what would be the best way to do this without another amp? The powered sub has "speaker outs" can I get a powered signal from there to the 12" Sony? THANKS!
jpl20 is offline
Old 01-03-2013, 06:51 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
You need another amp to power the passive sub.
No.
eljaycanuck is offline
Old 01-03-2013, 02:10 PM - Thread Starter
jpl20's Avatar
There is no other way to tap into the power that is already there?
jpl20 is offline
Old 01-03-2013, 02:16 PM
Liked: 1800
Not that I'm aware of. AFAIK, a powered sub's amp powers only the sub itself - the power can't be "shared" with other (passive) subs.
Old 01-03-2013, 02:18 PM
pokekevin's Avatar
Liked: 102
You'd need an another amp to power the passive one. Use a Y splitter (RCA) with one going to the powered sub and another going to the amp and eventually to the passive subwoofer. The outs on your powered subwoofer wouldn't be the ones you want to use for your passive sub. Those are for if your L/R speakers.
pokekevin is offline
Old 01-03-2013, 03:38 PM
sputter1's Avatar
Liked: 42
Check this link, I had a similar conversation about this topic. You might find it useful.
http://forums.audioholics.com/forums/subwoofers/83490-possible-clipping-issue.html
sputter1 is offline
Old 01-03-2013, 05:27 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
The speaker outputs would use power amp level inputs and send a high level signal to the speakers. So they don't and could not use the sub's mono amp to provide stereo output and besides they are designed to keep the subwoofer frequencies out so they aren't an especially good power source for a sub
JHAz is offline
