Building a subwoofer with Def Tech cabinet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-04-2013, 09:09 PM - Thread Starter
ganpan's Avatar
Hi All,
I am a newbie without any technical experience. So would like some advice from you. Here is the situation: I have a spare Def. Tech supercube II subwoofer cabinet, but no components for it. I would like to see if I can build a subwoofer using that by buying components. My options to build this out are:
1) Buy Def. Tech amplifiers (low/high), woofer and 2 passive radiators from an authorized source - likely to be more expensive than buying a new subwoofer
2) Buy any 8"woofer, passive radiators and amplifiers from a kit - is this even possible ? if so where can I get it ? Would it even work ? the only thing I know is that the subwoofer volume is a very critical factor
3) Just not worry about building it as I will never get the sonic characteristics right if I use a third party kit and buying components from Def Tech is likely to be more expensive than buying a whole new subwoofer.
Let me know what you think. Appreciate your help.
ganpan is offline
post #2 of 5 Old 01-04-2013, 10:30 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
3, you're better off buying a 15 or 18 inch sub and making a new enclosure
stormwind13 is offline
post #3 of 5 Old 01-05-2013, 12:14 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You could make use of that sub cabinet. You will never match DT's bs claims, but you could get a sub with 100 db output capability down to about 30hz for about $250
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-458
http://www.parts-express.com/pe/showdetl.cfm?partnumber=301-510
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-492
You have to add at least 200g of mass to each PR (300g would be better), which would mean finding washers that fit the PR, and weighing them out.
Jay1 is offline
post #4 of 5 Old 01-05-2013, 08:49 PM - Thread Starter
ganpan's Avatar
Thanks for the help and the parts list. That would be a decent sub for that price, with the experience of building something out. Def tech says they have a low level and high level amp in the sub. Is the Yung class D amp module good enough ?
ganpan is offline
post #5 of 5 Old 01-06-2013, 12:32 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
With the drivers shown in that cabinet size, that amp works very well. I have no idea if you would have to modify anything on the cabinet to make any of those components fit though.
Jay1 is offline
