manual speaker setting for subwoofer on pioneer VSX-1021k - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2013, 01:57 PM - Thread Starter
bigshot82's Avatar
receiver: VSX-1021K
fronts: polk monitor 70
center: polk cs15
I recently purchased a Martin Dynamo 300 sub to add to the system. I am trying to figure out what's the best setting... If I set fronts to "large", subwoofer will work only with a dolby digital signal (with LFE channel). for 2 channel sources(even under dolby prologic or neo), low frequency components will go into the fronts. If I set fronts to "small", all low frequency components go through subwoofer at all times. which way is the best?
also, I set the sub on a fairly thick carpet... would that inversely affect bass quality?
bigshot82 is offline
post #2 of 4 Old 01-08-2013, 11:15 AM
Alan P's Avatar
Quoted: 5083 Post(s)
Liked: 3771
The usual recommendation is to set all speakers to "small" and all crossovers to 80hz. This will generally get you the best sound and sub integration.
Alan P is offline
post #3 of 4 Old 04-20-2013, 12:42 AM
Doublej74's Avatar
Thank you! I was so annoyned playing music via Apple TV. It sounded so empty without the sub and for whatever reason my fronts were set to 'large' . Changed to small and sub is working now.
So much better!
JJ
Doublej74 is offline
post #4 of 4 Old 04-20-2013, 10:38 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 719
If you have a capable sub, set the speakers to small. A capable sub will play the lower frequencies better, less effort and cleaner than you mains.
derrickdj1 is offline
Pioneer Vsx 1021 K 7 1 Home Theater Receiver
