Sub preout cable requirements - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-05-2013, 10:56 PM - Thread Starter
mginster's Avatar
Does the RCA used for preouts to a powered sub matter that much as far as higher gauges etc? I want to relocate my sub about 15 feet from the receiver and have a cheap 25 ft mono RCA cable. Will a higher quality one actually matter?
mginster is offline
post #2 of 3 Old 01-05-2013, 11:07 PM
Bond 007's Avatar
Quoted: 2376 Post(s)
Liked: 1914
Bond 007 is offline
post #3 of 3 Old 01-05-2013, 11:13 PM
hermeslyre's Avatar
El cheapo RCA will work fine.
If you were running a much longer distance you'd want to spend a couple bucks on a better shielded cable. That's it.
hermeslyre is offline
