What's your subwoofer level relative to Reference Level? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 94 Old 05-01-2017, 04:37 AM
In.vincible's Avatar
Quoted: 220 Post(s)
Liked: 93
I settled at +3 on the sub from where Audyssey set it. That, along with DEQ at the 15 dB offset, works pretty well for music. I don't use any boost for movies, but keep DEQ at 0 offset.
In.vincible is offline
post #92 of 94 Old 05-01-2017, 07:38 AM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1249
I mentioned I was 42 so this was 4 year ago! I will have to read but I am not sure what sub system I owned back then. Anyways, still running subs at 10-12 dB hot and listening at reference with MV. I can see where running WOTW pods emerge on a continuous loop could be bad but usually big and loud scenes are short in duration.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #93 of 94 Old 05-01-2017, 09:16 AM
HondaF17's Avatar
Quoted: 73 Post(s)
Liked: 24
Great thread, thanks for bumping this up.
I have a Denon 4200. Ran Audyssey and level matched to 75db at about 25% gain on my Outlaw. Then Audyssey set sub trim to -4. I normally watch at -10 reference so my sub would be -14 reference?
I would have to increase trim in Audyssey to +10 in order to be at reference?
If so, I might try boosting trim +4 and see if I can tell a difference...then go up or (back) down from there.
HondaF17 is offline
post #94 of 94 Old 05-01-2017, 02:20 PM
MKtheater's Avatar
Liked: 1249
No, it is at reference at -4, or should be. If you turn it higher then it is hot accordingly.
Marantz 7702 Atmos
