What size sub for a 18'x12' room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-08-2013, 07:13 AM - Thread Starter
mym6's Avatar
I've had this set of speakers for years (http://usa.yamaha.com/products/audio-visual/speaker-systems/speaker-packages/ns-p220/?mode=model#list=within&mode=paging&page=5) and they're honestly ok most of the time. The sub as you can imagine is pretty weak at 50W (not sure if that is peak or RMS, my guess peak) and only 6.5". Finding a spot where that sub did anything at all was a small challenge of its own.
For a 18'x12' room what would be a more appropriate size sub? This is how the room looks - http://cl.ly/M1IV
Linux based Apple file server made easy
ControlPlane - Make your mac context and location sensitive!
mym6 is offline
post #2 of 7 Old 01-08-2013, 10:43 AM
Alan P's Avatar
Quoted: 5084 Post(s)
Liked: 3772
Posting your budget is pretty neccesaryl for people to give you any sub recommendations. Typically, no one is gonna recommend anything smaller than 12" for that room.
EDIT: Oh, and to find the best spot for your sub, try the "sub crawl" (just search the forum, you'll find it).
Alan P is offline
post #3 of 7 Old 01-08-2013, 11:40 AM - Thread Starter
mym6's Avatar
It dawned on me to search google a bit and found some tips. Looks like a 12" would be about right and I'm currently considering this guy - http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=Y22XBDZ3VX4J&coliid=I1WC5XL43C242J
mym6 is offline
post #4 of 7 Old 01-09-2013, 02:20 AM
popalock's Avatar
Quoted: 1295 Post(s)
Liked: 1805
I read the title and just had to laugh...
Not at you or what you are asking. Not by any means, so don't take it that way.
I just laughed thinking about what other bassheads would respond with. For instance, my space is 13.5D x 14W x 8H, bringing me at about 1,500ft^3. Assuming you have 8ft ceilings, you would have a bit over 1,700ft^3.
Google says a 12" sub should be about right... I currently have 2 18's in my room, and I'm in the process of upgrading to 16 18's. Now, I realize that is obviously ridiculous to all but a handful of people (even on this forum), but I guess what I am getting at is that it's all relative.
I tell you what, once you have a system capable of a flat response down to 5hz or so, you will not want to go back to anything less....
I've heard good things about the BIC and it will be a huge upgrade from what you have now.
Enjoy!
popalock is offline
post #5 of 7 Old 01-09-2013, 05:57 AM
sputter1's Avatar
Liked: 42
Enjoy!
16 18" subs in a 1500^3 room? Even at 1 sub being 2' cube they will pretty much ring the room unless stacked. I guess pictures will be coming.
sputter1 is offline
post #6 of 7 Old 01-09-2013, 06:20 AM - Thread Starter
mym6's Avatar
Enjoy!
Yea I figured I'd get a go big or go home, maybe something like this:
mym6 is offline
post #7 of 7 Old 01-09-2013, 12:23 PM
popalock's Avatar
Liked: 1805
Ring the room unless stacked?
Oh yeah, I'm sure I'll get around to starting a thread eventually.
If they only sold these... I'll take 2!
popalock is offline
Subwoofers
