Frusterated with failed subwoofer hookup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-09-2013, 07:16 AM - Thread Starter
Slim Bob's Avatar
Alright, I have a 5.1 setup in my theater room that I'm working on. Using a Harman Kardon AVR-2600, with 2 bookshelf B&W DM602 S3's up front, a center channel, and a couple of ceiling surround speakers in the back.
I bought a Pinnacle Baby Boomer sub woofer on sale after reading some nice reviews on it. My room is 9' x 25'. The fronts, center, and rear speakers all work great. My sub woofer powers on (and makes an audible noise within its box, so something is happening in there) but after about 5 minutes it goes into standby meaning it isn't receiving any sound signals. What the hell...
My two front speakers are using jumpers to connect the hi and low fidelity ports together. I've checked all polarity's to make sure I've got my + and - all correct. I used the supplied cable to connect the sub woofer to the "sub" port on the back of the AVR, but cannot get any bass to come out of the dang thing.
I've tried adjusting the AVR settings the the "Manual Speaker setup" but to no avail. I tried the "EZQ Autosetup", but it never detects a subwoofer within the setup.
PLEASE HELP! I have scoured the forums, done due diligence with google searches, but I can not find a fix for this. confused.gif
Slim Bob is offline
post #2 of 5 Old 01-09-2013, 07:35 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
A couple of thoughts:
- Have you accidentally connected the cable to the SUB PRE-INPUT on the middle of the back plate of the receiver instead of to the SUB PRE-OUTPUT in the lower left corner of the back plate of the receiver? (This has been known to happen.)
- If the above connection is correct - the cable runs from the SUB PRE-OUTPUT on the AVR to the L input on the sub - have you set the "crossover bypass" switch on the back of the sub to "ON"?
eljaycanuck is offline
post #3 of 5 Old 01-09-2013, 09:02 AM - Thread Starter
Slim Bob's Avatar
Oh wow, after all my nights of troubleshooting, all the time searching for this answer, I think u might be right. I never saw that output jack as it is really hard to get to it where my receiver sits. I just assumed there was only one purple sub jack. I will try that out over lunch and let ya know. Thanks and now I feel like an idiot. Haha
Slim Bob is offline
post #4 of 5 Old 01-09-2013, 12:10 PM - Thread Starter
Slim Bob's Avatar
It worked, haha. Thanks!
Slim Bob is offline
post #5 of 5 Old 01-09-2013, 12:28 PM
Liked: 1798
Subwoofers
