The "Official" Crowson Tactile Motion Actuators Thread. - Page 18 - AVS | Home Theater Discussions And Reviews
 33Likes
post #511 of 528 Old 02-01-2015, 07:52 AM
bjorg's Avatar
Quoted: 22 Post(s)
Thanks Red99! That's a similar diagram that Crowson had in their installation PDF. Just curious what the difference is for the amp for low vs. high impedance. Obviously, the lower it is, the lower the voltage between the speaker poles and the more amps must flow through. But what does that mean for the amplifier itself?
Abstract yourself!
bjorg is offline
post #512 of 528 Old 02-01-2015, 07:54 AM
bjorg's Avatar
Quoted: 22 Post(s)
BTW, I can confirm it was a bad actuator. When I switched them around, I got the desired effect in my listening position with my full weight and no other changes. So clearly it's possible to get a weak/defective actuator. Will have the installer reach out to Crowson for a replacement unit.
Abstract yourself!
bjorg is offline
post #513 of 528 Old 02-02-2015, 09:33 AM
bjorg's Avatar
Quoted: 22 Post(s)
I think I figured out my own question on the serial/parallel connection. If I understood Red99 correctly, the recommended setup is:
1) Put Behringer iNuke in BRIDGE mode
2) On each output channel, connect TWO actuators in SERIES.
The end result is a system impedance of 4ohm into which the iNuke delivers 3000W of pure butt-shaking goodness!
Is that correct?
Abstract yourself!
bjorg is offline
post #514 of 528 Old 02-02-2015, 09:39 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 1201 Post(s)
Liked: 1225
Is that correct?
Connect the two actuators in PARALLEL for a 4ohm nominal load.
EDIT: Sorry. I see you have four. You have a couple options. The easiest would be to not bridge the inuke and just run two actuators of each channel of it in 4ohm with two actuators hooked up in parallel.
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #515 of 528 Old 02-02-2015, 11:01 AM
bjorg's Avatar
Quoted: 22 Post(s)
You sure about that? I'm total noob at electric current, but I'm eager to understand.
Let's number the actuators #1 through #4 and call the channels A and B.
If I run #1 and #2 in parallel on A, then channel A has an impedance of 2ohm, no? Ditto for B.
However, if I bridge A+B, then connect two wires to A+B, then on each wire I run 2 actuators in series (e.g. #1 in series with #2 , #3 in series with #4 ), don't I get the series/parallel diagram that Red99 shared?
Something like:
* A+B -> (#1 & #2 ) // 8ohm
* A+B -> (#3 & #4 ) // 8ohm
Since A+B is bridged with 2 parallel 8ohm circuits, we get 4ohm. Correct?
Abstract yourself!
bjorg is offline
post #516 of 528 Old 02-02-2015, 11:06 AM
Bass Enabler
Liked: 1225
Yeah, I'm sure. It would work with no issues the way I described. No need or advantage to bridging the amp.
Each Shadow-8 is an 8ohm load.
So your choices are:
1) four 8ohm loads
2) two 4ohm loads
3) one 2ohm load
4) one 8ohm load
5) one 32ohm load
6) two 16ohm loads
So for you, really it's going to be either two 4ohm loads (two actuators in parallel) or one 8ohm load (all actuators in a series-parallel)
It would be easiest to just do two parallel in stereo. You can do the single 8ohm load with a bridged amp but it would just mean more wires going into the single output (harder to wire, imho).
post #517 of 528 Old 02-02-2015, 11:11 AM
bjorg's Avatar
Quoted: 22 Post(s)
Wow, I thought the actuators were 4ohm instead of 8, but you're right (and I just confirmed on the Crowson site). Now it all makes sense!
I appreciate your patience in explaining it!
Abstract yourself!
bjorg is offline
post #518 of 528 Old 02-02-2015, 11:18 AM
Bass Enabler
Liked: 1225
No problem. I'd have definitely thought what you did had they been 4ohm each.
post #519 of 528 Old 02-02-2015, 11:43 AM - Thread Starter
AVS Club Gold
craig john's Avatar
Quoted: 173 Post(s)
Liked: 398
The original actuators were 4 Ohms. The newer Shadow 8's are now 8 Ohms.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #520 of 528 Old 02-02-2015, 11:43 AM
Bass Enabler
Liked: 1225
I thought they were 6ohm?
post #521 of 528 Old 02-02-2015, 06:10 PM
ahmedreda's Avatar
Quoted: 53 Post(s)
Liked: 46
They are 8 ohms.. That allowed me to connect 3 in parallel to my bk1000 amp which is something i couldn't do with my bk lfe.
ahmedreda is online now
post #522 of 528 Old 02-02-2015, 07:03 PM
Bass Enabler
Liked: 1225
The older models, I meant, were 6ohm.
post #523 of 528 Old Yesterday, 07:22 PM
sslv2pwned's Avatar
Quoted: 119 Post(s)
Liked: 32
How many can be connected to one channel of an iNuke 6000?
sslv2pwned is online now
post #524 of 528 Old Yesterday, 07:48 PM
ahmedreda's Avatar
Quoted: 53 Post(s)
Liked: 46
2 in parallel.. You can also connect 4 by connecting each 2 in series then then in parallel.. That would be still be a 4 ohm total..
post #525 of 528 Old Today, 12:30 AM
Bass Enabler
Liked: 1225
Four Shadow-8's in series-parallel would be 8ohm.
post #526 of 528 Old Today, 06:56 AM
ahmedreda's Avatar
Quoted: 53 Post(s)
Liked: 46
You are correct. I miscalculated it. Each branch will be 16 and in parallel will yield 8.
post #527 of 528 Unread Today, 08:21 AM
sslv2pwned's Avatar
Quoted: 119 Post(s)
Liked: 32
So at 8 ohm, one channel should be plenty to run 4 of them to full capability, correct?
Sent from my Nexus 5 using Tapatalk
post #528 of 528 Unread Today, 08:54 AM
ahmedreda's Avatar
Quoted: 53 Post(s)
Liked: 46
Yes 1500 watts should be plenty. I am using the BK1000A with 3 and the actuators would max out before the amp runs out of power.
