The "Official" Crowson Tactile Motion Actuators Thread. - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 190Likes
post #811 of 950 Old 10-27-2016, 05:49 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
Originally Posted by Brian Fineberg View Post
You bought plywood from amazon for these? Do you have a link?
Actually it's medium density fiberboard.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #812 of 950 Old 10-27-2016, 05:59 PM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
How are those being placed? Are they riding on top of the carpet or hard surface backed?
Bunga99 likes this.
coolrda is offline
post #813 of 950 Old 10-27-2016, 06:59 PM
zeus33's Avatar
Quoted: 1410 Post(s)
Liked: 1086
Ouch. $6 for one 6"x6" piece of 1/4" MDF? Why didn't you stop by Lowes or Home Depot and have them cut down a piece of scrap?
Is 1/4" sufficient?
zeus33 is offline
post #814 of 950 Old 10-27-2016, 09:16 PM
notnyt's Avatar
Quoted: 2349 Post(s)
Liked: 2145
6" panels aren't going to make much of a difference. You're spreading what, 5x5 to 6x6 instead? unless you put spikes under it to go through the carpet...
notnyt is offline
post #815 of 950 Old 10-28-2016, 04:58 PM
Quoted: 279 Post(s)
Liked: 105
Riding on top of carpet.
post #816 of 950 Old 10-28-2016, 05:03 PM
Quoted: 279 Post(s)
Liked: 105
I went to both Lowes and Home Depot.
At Lowes there saw was broken and Home Depot refused to cut anything that small.
They said it was a safety issue.
post #817 of 950 Old 10-28-2016, 05:07 PM
Quoted: 279 Post(s)
Liked: 105
The carpeting is not thick at all.
It's more like indoor/outdoor carpeting.
post #818 of 950 Old 10-28-2016, 05:16 PM
notnyt's Avatar
Liked: 2145
probably wont even need a piece of wood then, can try it both ways pretty easy
notnyt is offline
post #819 of 950 Old 10-28-2016, 06:05 PM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
Likewise, I don't see a need for wood in your case. You might as well try it both ways and measure it but the MA's will actually burrow into the carpet and slowly increase the tactile output as it does.
coolrda is offline
post #820 of 950 Old 10-28-2016, 11:49 PM
Nalleh's Avatar
Quoted: 1014 Post(s)
Liked: 454
@coolrda : you went from 2 to 4 Crowsons, right?
Did you try 2 in the rear corners, and two in the front corners?
You recommend all 4 along the rear?
Triple Atmos Receivers
Atmos 13.1.8/DTS:X 9.1.8/AURO 3D 12.1
My setup:
http://www.avsforum.com/forum/29-wha...l#post41323201
Nalleh is offline
post #821 of 950 Old 10-29-2016, 04:33 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Mine will be here on 11/4. I'm going no wood. I have commercial carpeting on padding. Should be ok. I hope
Brian Fineberg is offline
post #822 of 950 Old 10-29-2016, 08:08 AM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
Yes, yes and yes.
Here's a further explanation. When I did all the seat and floor testing, I had an individual single seat unlocked. I initially planned on 5 tests, with MA's configured with 1(rear foot), 2(both rear feet), 4(all feet), dual array(2x each rear foot, side by side, 4 total) and stacked array(2x vertically stacked with 1" wood block isolator between them). With so much to test I only got half way through these tests. I never even measured the 4(all feet) configuration. I tried it for about 10 minutes with a few clips and preferred the rear only. While this is subjective only, they are pretty spot on to measured. This will all be tested thoroughly in the coming months. Ive never heard anyone going dual array or stacked array, but I gotta know what that measures and feels like.
How did it feel? With a MA at each foot it felt like a mini D-Box. This was with them sitting on carpet/pad. Think of it as intense but mostly single axis. What I've found is that even when your peak PSD is the same, 2 close or equal axes response is far more tactile than 1. With MA's in the rear only, you have a throw arc(tilt/hinge effect)even if it 1/1000 of a degree. I believe this excites the Y axis(frontback)to match and even exceed the Z axis(up/down). The other thing that comes into play is weight. Crowson says these are rated for 1000lbs but recommends 250lbs per MA. More MA's lower the ratio and it makes sense that increases TR as acceleration should increase. I'll have to measure that. What I do know is my seating is completely saturated setup as it is. All seats feel the same intensity and that's regardless if we're reclined or our feet are touching the ground. My recommendation is four along the back of a couch even if you need to add feet or build up a platform.
VideoGrabber and SBuger like this.
coolrda is offline
post #823 of 950 Old 10-29-2016, 08:47 AM
healthnut's Avatar
Quoted: 480 Post(s)
Liked: 315
Has anyone tried the new sorbathane isolators? Are they a significant uptake over the originals? At $35 each, I hope so.
healthnut is online now
post #824 of 950 Old 10-29-2016, 09:02 AM
SBuger's Avatar
Quoted: 242 Post(s)
Liked: 248
Yes, yes and yes.
Great info as always!
That's one of the things that I meant to ask you over in your VS thread about reclined vs not reclined. I was wondering if you got less TR reclined like I think @carp was saying he experiences with his HT chairs (but I think he runs only one iirc and that may make somewhat of a difference).
This has me a bit concerned about my future purchase of some new home theater chairs (still will probably be better than my couch). Brand and differences in build, even if minor may play a major role in the amount TR and the overall feel that the Crowsons provide.
SBuger is offline
post #825 of 950 Old 10-29-2016, 10:04 AM
carp's Avatar
Quoted: 2606 Post(s)
Liked: 1867
I have a few issues with my chair. I get a lot more feel in the arms of the chairs and yes, I get more feel when sitting upright then when reclined. Also with the feet up I feel more (too much) in the legs/feet. On top of all that, we just got new carpet with a real nice thick pad. Love it, but not for the Crowsons! I'll figure it all out eventually, but I think it will take more than 1 Crowson.
carp is offline
post #826 of 950 Old 10-29-2016, 11:52 AM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
Here's some info.
New Isolator Pics
My Take
coolrda is offline
post #827 of 950 Old 10-29-2016, 01:52 PM
Nalleh's Avatar
Liked: 454
Yes, yes and yes.
Thanks, that all make sense, and that was what i was thinking too. With one MA in each four corner, you get a Z "concentrated" movement, while with them in the rear, you get the tilt effect you speak of, that goes in several directions.
My couch consists of a interlocking right seat, a center section and a left seat. I made a wood frame to connect them all, and have one MA in each rear outer corner of that frame.
I LOVE the two Crowson's i have already, however i have two problems in really heavy scenes, like the famous deleted scene from Jurassic World, or choppers in Lone Survivor:
1. My amp goes in protect mode.
2. The thermal protection in the MA's gets triggered.
So if i get two more MA's, and mount them either in each front outer corner, or the rear inner corners of each seat, I get more headroom, AND more effective TR.
You read me?
My setup:
Nalleh is offline
post #828 of 950 Old 10-29-2016, 02:24 PM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
You read me?
Yep. That's my recommendation. 4x takes you to a new level. My well doc'd issues are gone with 4. Less distortion, no bottoming, the MA's run cooler. It's just performs much better when run along side the systems we use here. With 4, you'll have the single digit headroom and power to keep up.
coolrda is offline
post #829 of 950 Old 10-29-2016, 02:31 PM
coolrda's Avatar
Quoted: 862 Post(s)
Liked: 618
Thanks. Don't grip over HT seating. Most of the stuff today is built well. Look for something comfortable and aesthetically pleasing in the $3k/4 seats or abouts and your good. I think it's more about the ratio of 2 armrests per single seat cushion that runs the TR up.
coolrda is offline
post #830 of 950 Old 10-29-2016, 03:19 PM
healthnut's Avatar
Quoted: 480 Post(s)
Liked: 315
Here's some info.
New Isolator Pics
My Take
Thanks. They do appear to offer significant benefits, good to know
post #831 of 950 Old 10-30-2016, 12:31 AM
Nalleh's Avatar
Liked: 454
Word !
And yes, the MA's are absolutely most impressive in the single digits.
Now, where was my Crowsontech shopping cart again........
My setup:
Nalleh is offline
post #832 of 950 Old 10-30-2016, 04:41 AM
Liked: 3515
well IM hoping one does the job in my small HT with way seat the most important.....if not it goes back...not spending 2k on these things lol
post #833 of 950 Old 11-05-2016, 06:44 AM
Liked: 3515
all hooked up and installed
as if this second feels very similar to a buttkicker...need to dial it in.
anyone have any recommended settings on an inuke for one?
post #834 of 950 Old 11-05-2016, 11:43 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5411 Post(s)
Liked: 4361
Turn it down, cross at 40hz and calibrate delay so the timing is right.
From there, adjust level and/or lowpass filter.
Enjoy!
Scott Simonian is offline
post #835 of 950 Old 11-05-2016, 01:20 PM
Liked: 3515
already had it at 40hz...now time to dial in the level really...already feels better than the buttkicker
still some tweaking needed
but pretty impressed
post #836 of 950 Old 11-05-2016, 11:15 PM
VideoGrabber's Avatar
Quoted: 175 Post(s)
Liked: 109
Thumbs up
That's not surprising, and actually what one would expect, as long as the MA's were running in sync. (running front & back pairs out of phase would convert some of the motion to the transverse axis. y, in this case.)
This is something I'm really interested in hearing about (your subjective opinions).
With MA's in the rear only, you have a throw arc(tilt/hinge effect)even if it 1/1000 of a degree. I believe this excites the Y axis(frontback) to match and even exceed the Z axis(up/down).
It makes sense that it would. Is is easier for you to rock a row of seats, or lift one end straight up?
I'm sure you'll find that as the weight is increased an MA becomes less effective. Simple mass/energy relationship. So the converse would also be true. Fewer pounds of load/unit = larger displacement, or shorter time to reach a given displacement (=acceleration).
Couldn't hold it, eh? A new Reference Standard (it was SO good I pee'd myself.)
Well you DO have them distributed pretty uniformly, and plenty of 'em! Very intriguing report.
coolrda likes this.
VideoGrabber is offline
post #837 of 950 Old 11-07-2016, 05:20 AM
Liked: 3515
Enjoy!
so update....increased LPF to 45hz...and fiddled with levels...watched 13 hours last night.
yup thing is WAY better than a buttkicker....a BK you could feel the piston shaking the couch..not this...it just moves the couch as bass would. great addition...and for my 3 seat loveseat HT seating...one is PLENTY
this is as close the feeling I had when my HT was on a suspended floor as you can get to actually being on one (im now on concrete slab)
good stuff....worth the price of admission
post #838 of 950 Old 11-07-2016, 09:11 AM
Bass Enabler
Liked: 4361
post #839 of 950 Old 11-07-2016, 10:30 AM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 611
TT's certainly help in a basement. The wife booted me out of the upstair and there is a big difference in feel.
derrickdj1 is offline
post #840 of 950 Old 11-07-2016, 11:09 AM
Liked: 3515
Good. Now get another one.
http://youtu.be/byEGjLU2egA
