hookiing up subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-09-2013, 10:11 PM - Thread Starter
jc46's Avatar
Currently I am using the Speaker Level connections on the sub to hook up my Promonitor 800s. This is what is recommended in the manual. In addition to that, can I run a subwoofer cable from the receiver to the sub's LFE In port for the LFE signals? Or is this unnecessary? The configuration would be Speaker: Large and Subwoofer: Yes.
Would this not bypass the sub's Low Pass crossover and perhaps bass management will now be handled by the receiver? (I mean how else can the LFE signals get across the subwoofer cable)
jc46 is offline
post #2 of 3 Old 01-10-2013, 12:14 AM
derrickdj1's Avatar
Quoted: 884 Post(s)
Liked: 595
I don't think you need the cable.
derrickdj1 is offline
post #3 of 3 Old 01-10-2013, 07:27 AM
Bill Fitzmaurice's Avatar
Liked: 4682
Do you mean you're connecting the L/R speaker outputs on the receiver to the sub and then you're wiring the 800s into the mains outputs of the sub? If so, that's the wrong way to do it. Wire the 800s to the L/R speaker outputs of the receiver, send the LFE output to the sub.
Bill Fitzmaurice is offline
Subwoofers , Cables Interconnects
