Subwoofer and Static Eletricity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-09-2013, 11:14 PM - Thread Starter
Rayscordova's Avatar
I seem to be having a problem with my center channel i currently have a Definitive Technology CS-8060HD center channel with a built in woofer. when i place this woofer on my television stand it seems to have a very faint popping noise that comes out of the woofer. when i move the speaker to the other room to no feedback from the woofer. even on the floor next to the stand not feedback but as soon at is touches the stand i get feedback from the woofer.
Thanks for all the help in advance.
Rayscordova is offline
post #2 of 14 Old 01-10-2013, 03:37 AM
BeeMan458's Avatar
Liked: 813
At any point do you have metal-to-metal contact? A ground loop of sorts?
BeeMan458 is offline
post #3 of 14 Old 01-10-2013, 05:23 AM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
Describe the noise further. How often? What kind of tv, cables? More detail the better. Are you using a surge protector? Did this just start or did you just buy it?
Licence to Kill
Bond 007 is offline
post #4 of 14 Old 01-10-2013, 09:11 AM - Thread Starter
The noise is like sombody tapping on a pillow very lightly and it is coming from the center channel subwoofer. The only time i hear the sound is when the center channel is on the stand(the center channel has built in amplifier). Asnsoon as i take the center channel off the stand no more sound. Panny ST30 and connected to monster 900 surge protector. Just bought about two weeks ago.
post #5 of 14 Old 01-10-2013, 09:21 AM
Bond 007's Avatar
Liked: 2056
How is it connected? hdmi?
Licence to Kill
Bond 007 is offline
post #6 of 14 Old 01-10-2013, 09:38 AM - Thread Starter
The speaker is connected with speaker wire to the receiver and an lfe cable to the receiver as well. And also a power cord to the wall
post #7 of 14 Old 01-10-2013, 10:02 AM
Bond 007's Avatar
Liked: 2056
My guess is that it has nothing to do with the stand but rather the proximity to the receiver. How many watts is the receiver and how many is the center? How difficult would it be to move the receiver a few feet to test? Have you tried a different lfe cable? What kind are you using? Is it insulated? How long is the cable and where are you placing the excess when center is on stand?
Licence to Kill
Bond 007 is offline
post #8 of 14 Old 01-10-2013, 10:15 AM - Thread Starter
The center channel is 150 and receiver is 700 but I could not be the LFE cord because it does it when there is no speaker wire or LFE CONNECTED
post #9 of 14 Old 01-10-2013, 10:22 AM
Bond 007's Avatar
Liked: 2056
eek.gif Now we are getting somewhere. If you keep it plugged in in the same place but take it off the stand the sound stops? With no wires at all hooked up to the center?
Licence to Kill
Bond 007 is offline
post #10 of 14 Old 01-10-2013, 10:25 AM - Thread Starter
Yes you are correct
post #11 of 14 Old 01-10-2013, 10:32 AM
Bond 007's Avatar
Liked: 2056
Have you tried plugging it in somewhere else?
Licence to Kill
Bond 007 is offline
post #12 of 14 Old 01-10-2013, 10:35 AM - Thread Starter
Yes and to a completely different circuit and no sound but as soon as it touches the stand the sound is back
post #13 of 14 Old 01-10-2013, 10:42 AM
Bond 007's Avatar
Liked: 2056
What kind of stand is it? Seems fair to assume its not wood. Metal and glass? Is the floor carpeted? Anything at all that is on the stand that may be putting a current through it?
Licence to Kill
Bond 007 is offline
post #14 of 14 Old 01-10-2013, 10:47 AM - Thread Starter
The stand is on a carpet glass and metal. I have a panny bluray Xbox 360 and sc-63 pioneer elite receiver
