SPL Meter - Advice? Pics etc. ! - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2013, 06:07 PM - Thread Starter
Quicktime_GT's Avatar
Hello,
Let me start by saying that I don't know what I'm doing.
I purchased a cheap Scosche SPL1000 meter from ebay just to mess around out of curiousity.
My setup:
Denon 1910
Klipsch F-3
Klipsch C-3
Klipsch R-5800 Surrounds
(2) Sony SA W3800 15" woofers.
I started by placing the meter beside me on the couch... Playing some ghetto thump, the maximum read db was 112.1
With the meter 1 foot in front of a subwoofer, the max reading was 124.4db.
So what method should be used to find a comparative reading? Is a cheap meter such as this even remotely accurate?
Some pics:
Quicktime_GT is offline
Old 01-12-2013, 07:11 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Depends on what you want to compare against. At your LP is one measurement so you can determine how close to "reference" you're getting, an in-room close mic is another, outdoor ground plane is another. You have to have the specs of the measurement to make comparisons/judgements as to what the numbers represent....
For instance, what is the definition of max on your meter? Peak? Averaged max of some sort?
lovinthehd is offline
Old 01-12-2013, 10:39 PM
Bill Fitzmaurice's Avatar
Liked: 4668
Your meter is probably accurate, but it's not telling you anything worthwhile. To do that you need to read each and every frequency within the sub pass band on a chart. That requires a USB measurement mic and measuring software. If you're interested the DIY speaker and sub forum is where to find out about it.
Bill Fitzmaurice is offline
Old 01-13-2013, 04:31 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by Quicktime_GT View Post
Hello,
---snip---
This calculator link for sealed subs will give you a clue as to what your pair of co-located, 15" subs are capable of and go from there as to wanting to know if the reading of your inexpensive sound meter is accurate or not.
Here's what the big boys use if someone is wanting to explore their OCD nature. The cylindrical item on the right of the sample image is a calibration device. This unit is a calibrated unit that has it's very own calibration certificate. rolleyes.gif Note: accuracy is +/- 1.5 dB and this considering for our purposes, we live in a world where we look to +/-3 dB.
The point, despite added purchase expense, even with the good stuff coming pre-calibrated, with calibration documentation and included calibration device, in my opinion, as highly desirable as good testing gear is, the specifications aren't what I would consider to be the best. The point, at the main listening position, based on what the "Piston Excursion" calculator has to share and the inherent calibrated "inaccuracy" of top of the line measuring gear, it's my opinion that your readings are suspect.
As to measuring methodology, I believe that Bill Fitzmaurice above has suggested, in order to eliminate room caused interference, measuring at one foot gives the most accurate results but then one has to calculate out the fall off or decrease in volume to main listening position with all the foibles taking a reading at the main listening position adds to the mix.
Bill, if you might clear up any hash that I might have made in my above layperson's explanation, that would be kind of you.
BeeMan458 is offline
