Dual subs in a not so big room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-13-2013, 12:37 PM - Thread Starter
sensui's Avatar
Well I thought I was set on a pair of Seaton submersives for a 2500 cubic feet family room opening to the kitchen. With more thought afterwards, I really will be using the subs for home theater and will prefer to use the full range floorstands only for music.....so I am slanting toward a pair of the JTR 2400 Captivators passively. Here is the issue, because I can't bring myself to do inwalls/onwall speakers, I want to get floorstanding ones so the wife is moving me to the upstairs den.....which is a 1500-1600 cubic feet room that opens to a large area (2 stories of space where the staircase is). Would having a pair of subs be still a good idea? I want good frequency response for sure but with such a small area it might be overkill/counterproductive with 2 of the JTRs? I am looking to achieve good LFE this time.....feeling the rain on your skin during a downpour scene for example in a movie. Any opinions are welcome and I thank you in advance.
sensui is offline
post #2 of 9 Old 01-13-2013, 12:50 PM
ack_bk's Avatar
Quoted: 617 Post(s)
Liked: 698
Two is probably overkill. Start with one and go from there?
ack_bk is online now
post #3 of 9 Old 01-13-2013, 12:54 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Dual subs isn't about going loud, it's about smoothing room modes. If you don't think you need what two big subs will give get two smaller subs, just make your sacrifice in output, not extension.
Bill Fitzmaurice is offline
post #4 of 9 Old 01-13-2013, 01:02 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Would having a pair of subs be still a good idea? I want good frequency response for sure but with such a small area it might be overkill/counterproductive with 2 of the JTRs? I am looking to achieve good LFE this time ...
If two JTRs are too much, get two smaller and/or less powerful subs. In your relatively-small room, you'll still get plenty of performance, and you'll pocket some cash in the process. Examples (in alphabetical order by manufacturer) include:
- HSU VTF-15H
- PSA XV-15 / XS30
- Rythmik F15 / FV15
- SVS SB12-NSD / PB12-NSD
eljaycanuck is offline
post #5 of 9 Old 01-13-2013, 01:09 PM - Thread Starter
sensui's Avatar
With my configuration, going ported would be the smarter choice though correct (with the preference to use them exclusively for home theater)? I definitely want 2 subs to smooth out the response as much as possible throughout the room and I forgot to mention.....I do want a pair of the captivators or submersives because I'd like to be able to move them into a larger room when the time comes down the road (possible I guess, if the configuration in the family room changes). This is why I'm looking at the big boys, else I'd certainly be very interested in a pair of the rythmik fv15s. I guess one can just turn the subs down? =D
sensui is offline
post #6 of 9 Old 01-13-2013, 01:15 PM
Liked: 1964
A pair of XS-30s or XV-30s would offer tremendous performance in your current space - while saving you money - and still have plenty of performance on tap for a larger space down the road.
But if you integrate and calibrate the SubMs or Caps, they should work very well regardless of the size of room you put them in. smile.gif
post #7 of 9 Old 01-13-2013, 01:23 PM
ack_bk's Avatar
Quoted: 617 Post(s)
Liked: 698
If you have the budget than just grab a pair of Caps or Submersives and then you never have to wonder or worry if you move to a larger room.
post #8 of 9 Old 01-13-2013, 02:15 PM
dominguez1's Avatar
Quoted: 1119 Post(s)
Liked: 986
For that smaller room upstairs, I would probably go with a pair of subm's. You'll benefit from its sealed design in that smaller room which would allow you to dig a lot deeper than the Caps with meaningful output below the Caps tuning.
You can't go wrong with either though!
dominguez1 is online now
post #9 of 9 Old 01-13-2013, 03:12 PM - Thread Starter
sensui's Avatar
yeah....I keep teetering between the submersives and the captivators. I know for a fact I can't go wrong with either choices. Thanks everyone for reassuring me that it would work out for the space given, just because I have the power to destroy that room doesn't mean I have to use it. =P
sensui is offline
