Accurate and Musical Sub Recommendation for my 17' W x 30' L x 10' H room - ~$500 budget - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2013, 01:42 AM - Thread Starter
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
Hi guys.
My room layout looks like this:
My speakers are the Selah Audio SA1, stand mount two-way monitors with a Fountek ribbon tweeter and a 7-inch Vifa XT18W09 mid/woofer (rated frequency response of 44Hz-20kHz (+2/-3dB) and' a sensitivity rating of 86dB). The speakers are rear-vented, so they produce amazing bass for their size, but tend to become boomy sometimes. The receiver is Denon AVR-3313CI, so Audyssey EQ room correction will be available.
My room is as shown above (16.5' wide by 30' long and 10' high ceilings), with the main listening area effectively squared off in an almost 17'x17' area by the breakfast bar separating the open kitchen area from the main living area. Typical suburban townhome layout, with carpeted floors smile.gif
I am looking to add a subwoofer, and my intended usage is 70-80% BD movies / TV, and the rest for music ranging from Bach to Rock to Asian Classical music. I want a fast, musical and accurate sub capable of producing the punch when needed in the BD movies, but yet blend into the music when needed. Output at reference levels is not required, but would like to feel the punch of low bass around ~20-30 Hz. Mid and upper bass response is equally important. Size and placement flexibility is very important due to the peculiar layout of the listening area, so dual subs or even most MEDIUM-to-BIG subs are a no-go in terms of WAF and placement.
Based on a budget of ~$500 preferably, I've been reading great things about SVS, PSA, HSU and Outlaw subs. The new SB-1000 and PB-1000 subs from SVS are particularly appealing, but I am open to suggestions. I've seen Principals from SVS and PSA on this forum, offering advice, and it's greatly appreciated if they could chime in, along with the seasoned bassheads here.
Thanks in advance for entertaining yet another thread seeking recommendations.
P.S. Would it be batchit crazy if I hid the sub in the nook below the mantle? That way it will be away from sight behind the TV and the equipment stand, but enclosed in a 4'x4'x2' nook tongue.gifbiggrin.gif
raaj is offline
Old 01-16-2013, 01:48 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The nook might not be a bad idea, considering it is a corner. You would have to try it before you really know. The PB1000 seems like a good choice for $500
Jay1 is offline
Old 01-16-2013, 09:10 AM
Alan P's Avatar
Quoted: 4696 Post(s)
Liked: 3322
If I had a nook like that, I'd certainly give it a go! Nice hidden location.
Alan P is offline
Old 01-16-2013, 03:24 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
One PB1000 For that large a space is really pushing it. But it might get a boost in that Knook.
Id save up for a second one down the line.
Athanasios
nashou66 is offline
Old 01-16-2013, 03:33 PM - Thread Starter
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
Thanks for the replies guys!
I know the room looks gargantuan in the sketch, but I am practically listening to my speakers in the near field. The speakers are just about 10-12ft from the main listening position, and there is almost a half height wall (the breakfast bar) that effectively squares off the listening area to a 17'x17' square. And, I don't ever play at reference, but only at moderate listening levels - between -25 to -15 level on my current Marantz receiver (soon being replaced by Denon AVR-3313CI). So, the prime objectives are accuracy, speed and punch at these volume levels, and also size and placement flexibility.
raaj is offline
Old 01-16-2013, 03:50 PM
kesando's Avatar
Liked: 31
Keep in mind that because you have a large open area, any sub you purchase will try to pressurize the whole area, not just your 17x17 listening area. That said, the PB1000 should be adequate in that room if placed properly
kesando is offline
Old 01-16-2013, 04:44 PM - Thread Starter
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
Yup.. that makes sense. Other than the PB1000 for the output capability, any other recommendations in terms of speed, accuracy and size?
raaj is offline
Old 01-16-2013, 05:33 PM
Pete7874's Avatar
I like the PB1000 suggestion. One other that you may want to look at would be Outlaw LFM-1 Plus, currently at $549.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is offline
Old 01-16-2013, 05:34 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
At ~$500, the PB-1000 currently seems to be your best bet for output, extension and accuracy.
eljaycanuck is offline
Old 01-16-2013, 05:49 PM - Thread Starter
raaj's Avatar
Quoted: 96 Post(s)
Liked: 132
Comparing prices shipped, I am liking what I see with the SVS PB-1000 ($499), SVS SB-1000 ($499), SVS SB12-NSD ($649), Outlaw LFM1-Plus ($620). How do these options compare to each other, and aren't there any other subs that'd fit the bill?? I don't want to go much beyond the $500, if possible, as there are other upgrades to my system contending for $$$. The receiver and potentially the fronts are also on the upgrade list, so $$$ are at a premium. redface.gif
raaj is offline
Old 01-16-2013, 06:27 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I think with shipping the Outlaw would be well over his budget. I think the PB1000 is a good suggestion though and I would go with that one too with a $500 budget. You can always add a second down the road too.
ack_bk is offline
Old 01-16-2013, 08:13 PM
Pete7874's Avatar
Oops, you're right. I didn't realize Outlaw did not include shipping in that price.
Pete7874 is offline
Old 01-16-2013, 09:05 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
I would go for the Hsu VTF2 mk4. It'll have a lot more output than the SVS subs and should be near the Outlaw in output, and it will have good sound quality too, thanks to the Q control. You can adjust how sharp you want it to sound, and how much extension you want. At the moment there is a modest discount on it so you can get it for under $600 shipped. The thing is, as was said above, the subs are going to have to pressurize that whole open area in order not to get any serious bass nulls. I think you would want as much output as you can afford. My guess is, even with the louder Hsu and Outlaw subs, you won't get great bass at the chairs in the middle of the room, but I think you will get a decent bass sound at the couch as it is against a wall. You have a large room, 5100 cubic feet, which is more than any of these subs are made to handle.
shadyJ is offline
Old 01-16-2013, 10:29 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Not one of the major brands, but the Premier Acoustic PA 120 and 150 are great for movies and music. The 150 is a monter on the output side.
derrickdj1 is offline
