Car audio subwoofer for home sub box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2013, 09:21 AM - Thread Starter
ps2cho's Avatar
Hey guys,
So my dog ate my 8" Monoprice subwoofer.
The amp and internal wiring is OK,but the woofer has been eaten.
(He ate a candy cane, or 5...off the xmas tree and went NUTS)
So anyway:
I have in my garage an 8" JBL GTO subwoofer that I used to have in my car:
This one: http://www.amazon.com/JBL-GTO804-Reduced-8-Inch-Subwoofer/dp/B000FHAXPA/ref=sr_1_1?ie=UTF8&qid=1358439639&sr=8-1&keywords=8%22+jbl+gto
Could it be a drop in replacement, or would I have issues with the stock monprice amplifier?
ps2cho is offline
post #2 of 5 Old 01-17-2013, 10:12 AM
Bill Fitzmaurice's Avatar
Liked: 4666
One must use speaker modeling software to determine the suitability of any driver/box combination.
Bill Fitzmaurice is online now
post #3 of 5 Old 01-17-2013, 10:25 AM - Thread Starter
ps2cho's Avatar
I know the cu ft is OK.
Here are the specs:
Audio Specifications
Nominal Impedance 4 ohms
Peak Power 800W
Frequency Response 30Hz–400Hz
Sensitivity (2.83V/1m) 91dB
Power Handling (Peak) 800W
Power Handling (RMS) 200W
I cannot find anything on the nominal impedance and sensitivity for the monoprice stock subwoofer.
I know its 60W RMS though so it should be OK.
So its not a simple yes/no?
I figured the only thing that I need to worry about is the ohms? Then again, I am no electrical engineer....
ps2cho is offline
post #4 of 5 Old 01-17-2013, 11:59 AM - Thread Starter
ps2cho's Avatar
Just found this so I guess it won't work:
car stereo systems run of 2 to 4 ohm impedance. home theater systems run on 8 ohms. if you connect a 4 ohm speaker to a 8 ohm home stereo you will overheat the amp and burn it out. to fix this problem, hook your two 4 ohm 12" subs in series mode. to do this, connect the positive on sub #1 to positive output on the amp. take the negative on sub #1 to the positive on sub #2, then connect the negative on sub #2 to the negative on the amp. by doing this, you have converted your two 4 ohm subwoofer speakers into one 8 ohm load which the home stereo amplifier can handle.
ps2cho is offline
post #5 of 5 Old 01-17-2013, 12:08 PM
Liked: 4666
You have to worry about all this:
http://www.eminence.com/support/understanding-loudspeaker-data/
