BIC America F12 Vs PSW505 VS DSW PRO 440wi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-17-2013, 11:42 PM - Thread Starter
lasttimei's Avatar
Hi, i was looking on Google BIC America F12 vs PSW 505 and most people says F12 For movies and 505 for Music,
i will be using one for 50% games and 50% movies not much music.
The BIC America is around 200$
PSW505 250$
and i found this one not sure if its good as the other DSW PRO 440wi 8" for 242$ Manufacturer refurbished
on ebay.
250$ max budget
lasttimei is offline
post #2 of 7 Old 01-18-2013, 02:11 AM - Thread Starter
lasttimei's Avatar
atm psw505 is 190$
post #3 of 7 Old 01-18-2013, 06:04 AM
Nalow's Avatar
Quoted: 21 Post(s)
Well, you're comparing 12-inch subs to an 8-inch. Guess it depends on the room size and what existing speakers you already have.
I have the Polk DSW Pro 550wi (10-inch) in a 11x16 room and I almost feel as if it is overkill; it definitely hits and rumbles hard. I very easily could have gone with the 8-inch version.
Is space an issue?
Nalow is offline
post #4 of 7 Old 01-18-2013, 06:15 AM - Thread Starter
lasttimei's Avatar
space is not a issue room is some what small and actually i'm down with the polk or BIC because there under 200$ atm more concern for movies/games
post #5 of 7 Old 01-18-2013, 09:42 AM
Nalow's Avatar
Quoted: 21 Post(s)
I think it'd be a wash between the two honestly.
Both have similar frequency response ratings, both 12" drivers. The Bic's cabinet size is a lot bigger though. The Polk also has more continuous wattage; not that it's going to make or break your choice though.
May as well just go with whichever one you get the better price on and that you like the looks of best. There are plenty of happy owners of both. smile.gif
Nalow is offline
post #6 of 7 Old 01-18-2013, 08:16 PM - Thread Starter
lasttimei's Avatar
got the polk Thanks . just hope that my 15 amp for my room is plenty of power for all this crap i have connected
post #7 of 7 Old 01-19-2013, 08:30 PM
swarm87's Avatar
Quoted: 135 Post(s)
Liked: 104
can you report on how it is i am in the same boat as you and am trying to decide on a sub upgrade
pcm=potato
bitstream=patato
swarm87 is offline
Polk Dsw Pro 440 Wi Subwoofer
