Does the Polk PSW505 have too much power for my room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 01-19-2013, 03:40 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
The ceilings are vaulted and probably go up to around 15 feet or so. It's roughly a 16x14 room (we haven't moved in yet!). I have a pair of RTi4s and a CSi3 center to go with it. I want something that will certainly give a nice bass, but nothing too overpowering. I've heard to stay away from the PSW110, but even in a room this size would you still go with the PSW505? It's on sale at newegg and Amazon for $189, so I'm just curious what others think. Thanks!
butie120 is offline
post #2 of 22 Old 01-19-2013, 04:43 PM
XStanleyX's Avatar
Liked: 1269
The 505 will definitely not be overpowering in that room. I'd at least step it up to the RW-12d if your budget allows. Even it will not overpower that room. It's easier to turn the gain down on a sub than trying to turn it up on one that will choke in that room.
XStanleyX is offline
post #3 of 22 Old 01-19-2013, 05:04 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I agree, that room should easily be able to handle the 505 and something much larger without being overpowering. From what I've experienced, there is really no such thing as a sub overpowering an area....just tone it back if that feeling comes up.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #4 of 22 Old 01-19-2013, 06:16 PM
eljaycanuck's Avatar
Quoted: 1341 Post(s)
Liked: 1956
No.
eljaycanuck is offline
post #5 of 22 Old 01-21-2013, 02:26 PM
Jon S's Avatar
Quoted: 897 Post(s)
Liked: 281
The Polk PSW505 will not work well in that room. The subwoofer is too small for that volume. You really need a good 12" or 15" sub with a lot of power (even the12" might be inadequate).
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #6 of 22 Old 01-21-2013, 02:34 PM
Bill Fitzmaurice's Avatar
Liked: 5623
I'd go with a pair of twelves to smooth room modes. Maybe a pair of tens if the WAF is a concern.
Bill Fitzmaurice is offline
post #7 of 22 Old 01-21-2013, 08:35 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
I don't think my budget allows much more than the Polk 505 or the BIC F12. I'm not willing to spend $300 plus on a subwoofer.
Are you saying that the PSW505 or a BIC F12 won't sound good in this room?
butie120 is offline
post #8 of 22 Old 01-21-2013, 08:43 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I don't think it's a matter of sounding good or not, I just don't think that you will get a lot of what you're looking for out of it...bass because of the large area you have to fill. I've owned a pair of Bic America F12's.
AVR: Denon X2200W
Prime316 is offline
post #9 of 22 Old 01-21-2013, 09:01 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
So in a room this size, you would recommend the RW-12D? Would you even consider the Bic F12 or the 505 in this room?
butie120 is offline
post #10 of 22 Old 01-21-2013, 09:06 PM
XStanleyX's Avatar
Liked: 1269
If you really have to keep your budget down you can only do what you can do. A PSW505 behind the couch for possibly the best results. Add more subs later down the road. RW-12d's would be better though. Add one at a time as your budget allows til you're satisfied.
post #11 of 22 Old 01-21-2013, 09:08 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
If you're determined to not go over $300, I think it's your best bet. I haven't had any personal experience with the sub but from reading the threads on it, people seem to like it. You could also go for 2 f-12's but that would put you in the $400 range.
AVR: Denon X2200W
Prime316 is offline
post #12 of 22 Old 01-21-2013, 09:17 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
But wouldn't I need a receiver that allows me to connect two subs if I choose to down the road? I'm planning on getting the Denon 1613 once the price gets reduced. That's a 5.1 system.
I see Newegg has the RW-12 for $299 (originally $999????). Does Newegg typically have a sale on this sub for this price? That seems like a steal and maybe worthy of me paying that much for it.
butie120 is offline
post #13 of 22 Old 01-21-2013, 09:20 PM
XStanleyX's Avatar
Liked: 1269
You only need a splitter to run two subs out of the one sub out. The $999 price is bunk. Not any where worth that but a bargain at $300. Not sure how much longer that sale price will last. I'm guessing it will end soon and then be back on sale in a couple weeks or so. Maybe.
Yes, it's worth the extra bucks. I've owned both.
post #14 of 22 Old 01-21-2013, 09:21 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
Got it. Thanks. I appreciate all the information. Very helpful forum!
butie120 is offline
post #15 of 22 Old 01-21-2013, 09:23 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I own the Denon 1613...good receiver. Not too much extra power but has enough to get the job done.
I wouldn't pay that $999 price too much attention. I believe the sub has been discontinued for some time but they are still getting stock from some place and it does go on sale ever so often. Those that buy it feel that it's a great deal at $300 but aren't willing to pay much more than that for it.
I am running dual subs off of the Denon 1613 now. You only need to split the sub out on the receiver with a Y adapter and an additional subwoofer cable which both only cost a few bucks online.
AVR: Denon X2200W
Prime316 is offline
post #16 of 22 Old 01-21-2013, 09:25 PM
XStanleyX's Avatar
Liked: 1269
We just like to spend other peoples money.
post #17 of 22 Old 01-21-2013, 09:27 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Stanley, sell me that receiver for cheap.
AVR: Denon X2200W
Prime316 is offline
post #18 of 22 Old 01-21-2013, 09:30 PM
XStanleyX's Avatar
Liked: 1269
post #19 of 22 Old 01-21-2013, 09:31 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Ohhhhh, you're funnnn e.
AVR: Denon X2200W
Prime316 is offline
post #20 of 22 Old 01-21-2013, 10:22 PM - Thread Starter
butie120's Avatar
Quoted: 567 Post(s)
Liked: 101
Guys care to help me out in the "Audio, theory, and setup" forum? It's the "surround sound setup help w/pictures". It's a new house we're moving into, and while my wife is investigating paint samples and furniture (blah), I'm looking into how to set a room up like this up. Thanks!
butie120 is offline
post #21 of 22 Old 01-22-2013, 05:51 AM
Liked: 1956
post #22 of 22 Old 01-22-2013, 05:57 AM
Liked: 5623
An oversimplified but still useful equation for matching subs to mains is that the total cabinet size of the subs must be eight times that of the mains, or if the same size the displacement limited power handling of the subs must be four times that of the mains, or there can be a combination of size and power that gives the same overall net result. That's because the longest wavelengths produced by mains are about 10 feet long, those by subs 50 feet long; if a main is a sports car subs are dump trucks. Then there's the matter of room response, which you really can't get uniform using just one sub.
