dual svs sb12 nsd subs - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 01-27-2013, 11:15 AM - Thread Starter
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
figured it out for some reason my denon 2nd sub out is screwing with the polarity. works fine once i put a y adapter on the first sub out.
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #32 of 36 Old 01-27-2013, 11:16 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
This definitely sounds like a phase problem, like ceh said, switch the phase setting on ONE of the subs, not both, and see if it sounds louder. You are probably getting cancellation, which is where the peaks and troughs of the sound waves from the two subs are opposing where they meet at your listening position, and they can cancel each other out, leaving you with less SPL than just running one sub. As for the Klipsch sub, I haven't seen measurements for it, but I would guess it has a peakish frequency response with a lot of mid or upper bass but not so much deep bass. It will be made for big output at more easily perceivable frequencies, which is not what the SB12 is made for.
shadyJ is offline
post #33 of 36 Old 01-27-2013, 11:27 AM
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2893
Well, if the second sub out IS backwards setting the sub plugged into it's phase to 180 should also correct the issue.
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #34 of 36 Old 01-27-2013, 02:29 PM
kesando's Avatar
Liked: 31
Is it possible that SVS sent you an SB12nsd with the speaker leads reversed? I had this issue on two occasions with my SB12nsds where one was out of phase with the other. As per SVS the best solution is to remove the amp and switch the + and - leads as switching the phase from 0 to 180 doesn't completely fix the issue.
kesando is offline
post #35 of 36 Old 01-27-2013, 02:39 PM
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2893
I would think not, as both subs plugged into 1 sub out with a y adapter seems to have fixed the issue....
ceh383 is offline
post #36 of 36 Old 01-27-2013, 03:54 PM - Thread Starter
Quoted: 122 Post(s)
Liked: 82
all fixed with the Y adapter, now they have that punch that was missing before. What an outstanding musical sub. Highly recommend.
