Which sub should I get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-22-2013, 04:16 PM - Thread Starter
hingerson's Avatar
Quoted: 114 Post(s)
Liked: 49
I live in a apartment so I want to go with a small sub. The speakers I purchased are nht super zero 2.0s
So should I get the matching sub?
http://www.crutchfield.com/p_228SUPER8/NHT-Super-8.html?search=nht
Or could I get this save some money and be about the same?
http://www.crutchfield.com/S-OUsYctSIUOO/p_653S8B/Mirage-OMNI-S8.html?tp=187
Or do you guys have another option?
LG 55EG9100
hingerson is offline
post #2 of 14 Old 01-22-2013, 06:46 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4779
Do you want a small sub for the small footprint (size of the unit) or do you think a small sub will bother your neighbors less? Personally I'd get a bigger sub like the Klipsch RW12D, especially when on sale for $300 shipped from newegg as happens frequently. Just don't turn it up as much.
ps there's little value to "matching" subs. It's about frequency response, extension and spl.
lovinthehd is offline
post #3 of 14 Old 01-22-2013, 07:11 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 706
Ditto.
derrickdj1 is offline
post #4 of 14 Old 01-22-2013, 07:44 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
If you need a small sub, go for the Hsu STF1 over either of those, it is about the same price. If you want deeper bass and can handle a somewhat larger sub, look at the Hsu STF2. If you want a sub that will get loud, go for the Klipsch RW-12d, if it is on sale.
shadyJ is offline
post #5 of 14 Old 01-22-2013, 08:58 PM - Thread Starter
hingerson's Avatar
Quoted: 114 Post(s)
Liked: 49
Having a small foot print isn't all that important it was mostly not wanting to be the `menace` neighbor but hadn't really considered that I could just turn it down. Sorry this is my first set up outside of a sound bar, shadyj what makes that sub better? Its certainly in my price range. Thanks again for your help guys smile.gif
LG 55EG9100
post #6 of 14 Old 01-22-2013, 09:07 PM
shadyJ's Avatar
Liked: 1351
I think the STF subs will dig a bit deeper in bass, the STF2 especially. Their larger cabinet ought to make them a bit more efficient down low, they have more powerful amps, they have longer warranties. The Klipsch sub ought to get a lot louder than any of these, right now it is in stock at newegg.com for $350 and free shipping. Anyway, in the face of these better choices I would definitely skip the Mirage and NHT subs.
shadyJ is offline
post #7 of 14 Old 01-22-2013, 09:22 PM
lovinthehd's Avatar
Liked: 4779
Not sure about level but am pretty sure the Klipsch will exceed the Hsu 10" offerings and extend much lower, to 20hz fairly reliably. At $300 the Klipsch is a very good deal (and goes there regularly shipped), and even at $350 is worthy of consideration.
post #8 of 14 Old 01-22-2013, 09:22 PM - Thread Starter
hingerson's Avatar
Quoted: 114 Post(s)
Liked: 49
Thanks shadyj I'm going with the Hsu STF1 seems to be a phenomenal value according to what I've been reading really appreciate the help.
LG 55EG9100
post #9 of 14 Old 01-22-2013, 11:37 PM
shadyJ's Avatar
Liked: 1351
I agree, the Klipsch might be able to dig deeper, but I think it is tuned higher than 20 hz, so I doubt it is getting down to that point. I think its chief advantage is its output, not its extension.
shadyJ is offline
post #10 of 14 Old 01-23-2013, 06:51 PM
lovinthehd's Avatar
Liked: 4779
I don't know what it's tuned for, but was going on Archaea's measurements. I haven't actually measured mine yet. I was also remembering only the STF1's spec at 32hz, not the 25hz stated by Hsu on the STF2.
post #11 of 14 Old 01-23-2013, 07:01 PM
Rasta Linus's Avatar
Rasta Linus is offline
post #12 of 14 Old 01-23-2013, 07:21 PM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
Neither the stf1 or 2 as a larger cabinet than the rw. Neither one has a more powerful amp either. Just from listening I would say the rw goes every bit as low as the stf2 and is a lot louder. I had an stf2 and returned it for an rw. I would rather have one rw than 2 stf1s.
Licence to Kill
Bond 007 is offline
post #13 of 14 Old 01-24-2013, 03:46 AM
WhskyTangoFoxtrt's Avatar
Quoted: 77 Post(s)
Liked: 58
I think shadyj was comparing the HSUs to the NHT and Mirage subs while commenting that the Klipsch will have the most overall output for the money.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #14 of 14 Old 01-24-2013, 05:45 AM
Bond 007's Avatar
Liked: 2056
I see. I re read the whole thread and that makes sense.
Licence to Kill
Bond 007 is offline
