Sub setup ?'s - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 68 Old 01-28-2013, 07:03 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
My "water heater" has arrived. At first look I was concerned, the box had substantial damage and it was not double boxed. After unpacking everything I can see no apparent physical damage.
Hookup will have to wait until tomorrow, I thought I had a Y adapter....but I don't....
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is online now
post #62 of 68 Old 01-28-2013, 07:03 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
Deleted,
Duplicate post...
post #63 of 68 Old 01-29-2013, 07:29 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
Well, I got a Y adapter and got everything hooked up.
Initial down and dirty setup...
AVR XO 80Hz
SVS XO 50Hz
All trim levels set to 0
Speaker distances set to approximately the correct distances
Used SPL meter to roughly set sub gain levels.
Did not run Audyssey, so no room correction at this time.
Initial thoughts...
I played the first attack scene from Master and Commander
Cranked the volume to -5db (I know it's not accurate yet)
And Holy cow...IT SOUNDED PRETTY DARN GOOD
With the SVS sub set at 50Hz there is no way I should be able to "Localize it" but I could..
Perhaps I just wanted to hear it, so I did. It's about 5 feet away from my chair, it was almost like I could feel the pressure from it....I don't know...
At this point, I am looking forward to getting everything dialed in so I can hear what it can really do....
post #64 of 68 Old 01-29-2013, 08:33 PM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
Why no audyssey?
pokekevin is offline
post #65 of 68 Old 01-29-2013, 08:42 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
Originally Posted by pokekevin View Post
Why no audyssey?
It was just a quick down and dirty setup when I got home from work. A more painstaking setup attempt will hopefully happen this weekend.
I'm waiting for a sound card and some cables so I can get my laptop hooked up to do some room sweeps with REW in all of the subs various tuning modes.
I want to find out what the room likes best before running Audyssey....
post #66 of 68 Old 02-01-2013, 06:48 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
I am completely lost with REW, I know the results are not correct.
I've gone over the sound card calibration steps at least 30 times, the results look like they should.
I've tried loop back multiple times. I have checked and unchecked SPL "C weighted" ...etc
Every time I try to measure, I get this...
There is no way in H*&% this is correct...
post #67 of 68 Old 09-20-2015, 05:19 PM
jp381242's Avatar
Quoted: 56 Post(s)
Originally Posted by ceh383 View Post
Basic room layout... The room is 13ft wide (not shown in the layout)
The front speakers are DefTech 8060ST's, each has a 10" sub with 300watt amp built-in. According to DefTech, the subs will go down to 20Hz, I think it's closer to 30Hz.
I have purchased an SVS PC12-PLUS, that will hopefully be here Friday.
This gives me the possibility of having 3 subs hooked up. If I understand correctly, multiple subs help smooth room response.
Given not all the subs are the same, is it worth trying to use them all?
Or would I be better off using the DefTech's speaker level inputs only and trying to dial in just the SVS?
Opinions, suggestions....All are welcome....
Thanks in advance....
What did you ever end up doing? You seem to know a lot about def tech setups from my other post. I am waiting on my 8060STs and Center. I don't know that my Polk 505 Sub is the same "quality" but I have always enjoyed it. How do you setup and mix the 3 subs together? I would use the LFE outputs. I have a Pioneer AVR so MACACC is my software. Thanks!
jp381242 is offline
post #68 of 68 Old 09-22-2015, 09:00 PM - Thread Starter
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2868
Well, a lot has changed since this thread was started. First, the SVS was moved 7' back to the other side of the stub wall. The AVR has been changed, the 3313 went into the beedroom, it was replaced by a 4520, well 2 of them...both had problems and were replaced by a Yamaha RX-A2020. A miniDSP was added for sub tuning. The AVR has 2 sub outs and EQ's them seperatly. Sub 1 goes to the 8060's, each with it's own filter settings and sub 2 goes to the SVS with a different filter. After this was done I ran YPAO, everything plays pretty well together now...
