Recommendation on Velodyne EQ Max.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-25-2013, 12:54 AM - Thread Starter
dawgincontrol's Avatar
better for 2 EQ Max 10s or 1 EQ Max 15? Room is 25 X 18 and mostly music (70/30) over HT.
dawgincontrol is offline
post #2 of 3 Old 01-25-2013, 02:38 PM
Blacklightning's Avatar
Quoted: 411 Post(s)
Liked: 282
I would recommend 0 EQ Max if you are doing music and 1 EQ MAX 15 if you are doing HT.
The EQ MAX 15 covers a very small range, I can't imagine what a couple of EQ MAX 10s could do.
http://www.audioholics.com/reviews/speakers/subwoofers/eq-max-15/eqmax15longtermoutputcompression.jpg/image_view_fullscreen
The EQ MAX can play loud but I have seen better extension on ID 10" subs. So I guess my final answer would be the same thing I did.
Step 1: Buy EQ max (12 in my case)
Step 2: Watch All 6 movies of star wars (Listen to the EQ max's One note)
Step 3: Add sub to 2 channel setup and test tracks
Step 4: return EQ max or put bleach in your ears. ( I chose the return mine)
Step 5: Enjoy music again in the 2 channel setup
Step 6: Turn the volume down on the Movie system as your mains will be playing full range
Step 7: look into an Internet Direct sub. SVS for movies or Rythmik sealed for music.
Blacklightning is offline
post #3 of 3 Old 01-25-2013, 11:05 PM - Thread Starter
Went a different way and got the PSA XV15. Thanks for the reply. Glad it was you who tried out the EQ Max and not me after reading that!! smile.gif
