If It Ain't Broke, Don't Fix It... If You're Me, & It's Slightly Broken, Still... Don't Fix it. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-27-2013, 01:24 PM - Thread Starter
greywoodfoxhall's Avatar
So, I had to take a Sony SA-WM500 active sub-woofer (http://store.sony.com/p/SA-WM500/en/p/SAWM500), from Best Buy a few years back when I blew the sub that matched my Cerwin Vega floor speakers (I got the CV set-up for super cheap as BB was discontinuing it from their product line) and used my warranty. It was no replacement for the Cerwin Vega sub... I love my Sony Receiver, DVD player, and PS3... but my experience with this sub was that Sony can't make subs worth poop. I was busy moving around the country soon after and didn't even have it in my possession from 2006 to 2007. The sub always made this fart-like noise, the shield would never stay on, and it just didn't 'hound' like the Cerwin Vega did. I recently showed it to the guy who installed my parents' new "super-system" as part of their house remodeling and "showing me they weren't as broke as they told me I had made them" project (ha). He listened... affirmed that the sub didn't sound right, and suggested that I take some methamphetamine, turn on a techno song on repeat, and take the box apart and in all likelihood, I would find a wire loose in the box (okay, he only told me to take the box apart and look for the loose wire). So, I carefully took the amp apart enough to gain access to the box (didn't use one of those 'grounding' bracelets though... frown.gif no good, I know). When I got into the box, I only found two wire bundles that were nowhere near the sub-woofer. I still used electrical tape and stuck them to the sides of the box... reassembled it & the amp, and patted myself on the back. Mission accomplished... if my mission was to make a slightly annoying, but bearable and functional sub-woofer into trash. The sub-woofer turns on still... but the only sound I get from it are the "fart" noises when the volume is turned all the way up and a deep bass note is hit. Otherwise... it is a sub, as in a silent vehicle that I want to throw into the ocean (not filling it with seamen first though). What might I have done here? Is there any hope of recovery? How much could I sell this for as is? How much would a new amp/power source cost? Any thoughts, suggestions, advice, offers (repair or purchase), or even laughs at my stupidity or my multitude of stupid puns will be appreciated. Thanks!
~f.xy
greywoodfoxhall is offline
post #2 of 4 Old 01-27-2013, 01:50 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
I'd toss the Sony and get something better. Assuming you want something better an not just another fart-box. wink.gif
eljaycanuck is offline
post #3 of 4 Old 01-28-2013, 09:14 AM
Shadowdane's Avatar
If you have the gain on your sub turned all the way to the maximum no wonder it sounds like crap... your probably clipping or overdriving the subwoofer.
Shadowdane is offline
post #4 of 4 Old 01-31-2013, 08:17 AM - Thread Starter
Before and after the DIY repair, I tried adjusting everything from the frequency cut-off, the phase, and the level to no avail. The gain has to be at max to get any sound now that I 'broke' it. I guess what I am asking is... how can I tell if I fried the amp (like with an Ohm meter or something)? The speaker itself has no tears or scratches, so I doubt the trouble lies there.. The whole situation baffles me. Thanks for the help y'all.
Peace,
~f.xy
