Sub recs for PSB system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2013, 09:47 AM - Thread Starter
gbandi's Avatar
Hi there,
i am setting a HT in my basement. the room is 15x15' but opes to 15x8 space in back and large entertainment area on left. i am getting a front projector with 110' screen. the speakers would be PSB w1 wall mounted LCR and in-ceiling PSB surrounds.
Need a sub: budget <1000, relatively compact, <18 in max dimension
Need an AVR: considering integar 50.4, marantz 6007 and onkyo NR 818
60% movies, 30% cable, 10% music use
Thanks in advance. Please feel free to comment on speaker choice as well.
gbandi is offline
post #2 of 5 Old 01-29-2013, 01:37 PM
lewdogg's Avatar
WIth those size requirements I'd recommend the HSU ULS-15 as it's an 18" cube. A bit over budget but it's close. If you can squeeze a bit more room and/or $$ there are a lot of great choices.
HSU ULS-15: 1099+shipping
http://www.hsuresearch.com/products/uls-15.html
SVS PB-1000x2: 998 shipped
http://www.svsound.com/subwoofers/ported-box/pb-1000
SVS PB12-NSD: 769 shipped (a bit larger than you want)
http://www.svsound.com/subwoofers/ported-box/pb12-nsd#.UQg_wGetpVI
Rythmik F15: 974+shipping
http://www.rythmikaudio.com/F15.html
Rythmik F15HP: 1124+shipping
http://www.rythmikaudio.com/F15HP.html
Rythmik E15: 1174+shipping
http://www.rythmikaudio.com/E15.html
Rythmik D15SE 1049+shipping (not sure if this is still available)
http://www.rythmikaudio.com/D15SE.html
I'm sure there are plenty I missed...
GOOD LUCK!
lewdogg is offline
post #3 of 5 Old 01-29-2013, 09:15 PM - Thread Starter
gbandi's Avatar
How would a ported svs pb12nsd compare to sealed f15 or uls-15?
gbandi is offline
post #4 of 5 Old 01-30-2013, 01:34 PM
lewdogg's Avatar
http://www.avsforum.com/newsearch/?search=sealed+vs+ported&resultSortingPreference=relevance&output=all&containingforum[0]=113&type=all&advanced=1
That search should get you an answer...
lewdogg is offline
post #5 of 5 Old 01-30-2013, 09:16 PM - Thread Starter
gbandi's Avatar
@lewdogg
I went through 5hr of forum reading about subs and called Hsu, rhythmic and svs. Your recs amazingly match what all these manufacturers suggested. My take is svs seem to do better with ported subs for large room size, Hsu and rhythmic may be ok with sealed ones as well. The powerhouse would be fv15hp. I am trying to decide between fv15hp, e15 and uls15. They all are within $150 of each other. Uls has the wireless which is attractive. Can I use third party wireless for rhythmic? Which one will the pro's choose and why?
Gary
gbandi is offline
