Budget sub with at least 1 dimension 9" or less? - AVS Forum | Home Theater Discussions And Reviews
Old 01-30-2013, 09:18 AM - Thread Starter
TheBlubbs's Avatar
Quoted: 26 Post(s)
I am looking for a sub to place somewhere under my bed for my secondary setup.
I have an old AV123 X-sub that I could put there but if I were to replace it in my main setup it would make my main setup look weird to replace it with a larger sub.
Are there other options?
TheBlubbs is offline
Old 01-30-2013, 12:29 PM
Shadowdane's Avatar
That's a tight fit... you would probably have to build it yourself. Or maybe use a premade car subwoofer enclosure like this one: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-636
You'd need an external amp if you go that route though. You also need a subwoofer that can do well in a small sealed enclosure.
Shadowdane is offline
Old 01-30-2013, 01:43 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
I would put the existing sub under the bed and start looking for a subwoofers that would fit your main rig.
qguy is offline
Old 01-31-2013, 08:21 AM
JimWilson's Avatar
Quoted: 1275 Post(s)
Liked: 1592
Something like the Yamaha YST-FSW150 or OSD SS8 might work. They're both pretty thin.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
