Sub for the bedroom [F-12/PSW505] - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-30-2013, 11:22 PM - Thread Starter
Shibuya's Avatar
I'm looking to buy a sub for a small bedroom (replacing a z623 Logitech PC speaker sub that's hooked up to my receiver) and I'm wondering what's the best choice for under $200.
60% (music) / 40% (TV/Movies)
I was looking at either the BIC F-12 or the Polk PSW505. Is either a clear winner?
I thought it might be overkill for a small bedroom but I thought it'd be wise to spend ~$100 more for one of those instead of getting a mediocre Pioneer SW-8? (or maybe it's not that mediocre?)
$200 is the absolute limit.
Shibuya is offline
post #2 of 2 Old 02-01-2013, 07:16 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
In this forum, you can do a search on Archaea who did a very good review on the Pioneer SW-8. It measures exceptionally poorly.
The BIC F12 is probably the most recommended sub at ~$200 in this forum. It will play somewhat lower than the Polk PSW-505. You would probably be happy with either.
wwinkler is offline
