How to locate the Best in ceiling Sub Placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-31-2013, 06:50 PM - Thread Starter
Srgtfury's Avatar
Hi All,
I have a giant room, with 15 foot high ceilings and open to large areas of house. Wisdom SC1 controller and Sage L75i speakers (40Hz on low end). Surrounds are in ceiling/soffit ML Vanquishes. Now. I have a Wisdom STS (50X30X18 inch) sub, that can only be placed, on its side, in ceilingand across joists. The issue is where to place it. Some flooring has wood and other carpet (listening area), but there is no opportunity to try different ceiling locations. Would a Velodyne FSR14 moved across the floor and somehow suspended a foot or so above floor level emulate the in-ceiling install/, to guide best placement or is anothermethod preferable?
Thank you very much
Fury
Srgtfury is offline
