Sub-1000/1200 or F12 or PSW505 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-01-2013, 09:53 AM - Thread Starter
pencerules's Avatar
Budget: Under $200
Size requirements: 10" or 12"
Room dimensions: 350 sq.ft. with dimensions shown below
Primary uses: Home Theater room
Listening habits: 90% movies and sports
Appearance requirements: None
Timeframe: None
I have two Klipsch Icon VF-36 floor standing speakers with Klipsch VC-25 center and VS-14 surrounds.
I am trying to decide between Dayton Audio Sub-1000 or 1200 (leaning more towards one of these due to price, or a BIC F12 or Polk PSW505 if there is much difference to the Dayton. I know the Bic and Polk are relatively the same with varying opinions, but I would probably lean to the F12 if I was to spend the extra money. I would really like a Klipsch RW-12D but the budget doesn't allow for it now.
I am curious if the Sub-1000 would be much different than the Sub-1200 in my room, and if later adding on another Sub-1000 would fill in the difference.
Thanks for the help.
pencerules is offline
post #2 of 4 Old 02-06-2013, 07:19 AM - Thread Starter
pencerules's Avatar
Any help would be appreciated.
post #3 of 4 Old 02-06-2013, 09:58 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Bic F12 is a great HT subwoofer for the price.
The Polk isn't a bad one either and it would be my choice as I listen to music and alittle more than just movies in my set-up
Looking at your seating placement and Speaker placement you are going to be missing out on some surround sound as your area isn't balanced
crazyrob425 is offline
post #4 of 4 Old 02-06-2013, 02:06 PM - Thread Starter
pencerules's Avatar
Thanks for the response. My surrounds aren't in the most ideal place right now but I hope to shift some things around soon.
