Paradigm’s Perfect Bass Kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-02-2013, 02:27 AM - Thread Starter
terryshep's Avatar
hi iv just upgraded to windows 8 and I cant get this to work with windows 8 no driver I keep getting I have a sub 25 and just changed my room around and cant calibrate it
please help
terryshep is offline
post #2 of 7 Old 02-02-2013, 03:39 AM
gsamples's Avatar
If the program loads onto Windows 8 fine you can right click on the executable and choose properties and one of the settings should let you choose run in compatibility mode for Windows 7, Windows XP, etc. Have you tried that?
gsamples is offline
post #3 of 7 Old 02-04-2013, 05:57 PM
kevinf's Avatar
I tried this and no go ,did you get PBK to run on windows 8?
kevinf is offline
post #4 of 7 Old 02-05-2013, 04:52 AM - Thread Starter
terryshep's Avatar
post #5 of 7 Old 02-05-2013, 01:01 PM
WagBoss's Avatar
just kidding,
try right clicking the program and running as administrator
WagBoss is offline
post #6 of 7 Old 02-05-2013, 05:57 PM
gsamples's Avatar
No. I have windows 7 on my machines. Did you try running as an admin?
gsamples is offline
post #7 of 7 Old 02-26-2014, 07:44 AM
dp19's Avatar
I know this is late but I just got mine working under Windows 8.1. You need to enable installtion of unsigned drivers. Here is a video explaining how to do this.
http://www.youtube.com/watch?v=UPm_6aejOlo
After doing that, re-install the PBK application and the driver should work.
dp19 is offline
