Recommend a sub to fit a roughly 11" wide cabinet space? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 07:54 AM - Thread Starter
trifishy's Avatar
Putting a surround sound system together for my dad and the only place the sub can go is in a open cabinet (I'm sure it's not recommended but it's the only option for them).
I've found that the Infinity PS38 would fit (10-5/8"W x 17-3/4"H). Is there any other out there that I should consider?
trifishy is offline
post #2 of 3 Old 02-03-2013, 08:16 AM - Thread Starter
trifishy's Avatar
Just saw that this will also fit the dimensions: PSB SubSeries 125.
trifishy is offline
post #3 of 3 Old 02-03-2013, 11:58 AM - Thread Starter
trifishy's Avatar
Just talked to my dad, he said it is 11" wide to fit in the cabinet (a little wider on the inside of the cabinet) and the height is adjustable so I just have to find something 11" wide or smaller.
If anyone knows of something to recommend I'd appreciate it. No worries if not.
trifishy is offline
