IB subwoofers - do it. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-05-2013, 11:32 AM - Thread Starter
michelevit's Avatar
I am in the process of buttoning up my detached man cave/home theater. I installed 2 15 inch Infinitie subwoofers powered by a bash 500 watt plate amplifier.
I mounted them into the wall and they vent into my garage.
very impressed with the difference they make. Demo with the volcano scene in 2012. Felt like I was there.
I highly encourage anyone to go the IB route when making their subwoofer decision.
michelevit is offline
post #2 of 10 Old 02-05-2013, 11:45 AM
raaj's Avatar
Quoted: 97 Post(s)
Liked: 133
I used to have a sub installed IB-style, venting into the trunk in my previous car, and it was some of the most musical and tight bass I've ever heard. When implemented and integrated properly into the overall system, IB (infinite baffle) could be a great option for DIY installations.
raaj is online now
post #3 of 10 Old 02-05-2013, 12:33 PM
Shadowdane's Avatar
In that application though your more so using your trunk as one big subwoofer box. Granted I doubt the trunk is sealed that well, so wouldn't act the same as a large sealed enclosure.
Shadowdane is offline
post #4 of 10 Old 02-10-2013, 02:00 PM
Wrager's Avatar
Quoted: 192 Post(s)
Liked: 114
They are awesome and probably the best, least expensive solution. I've done a couple over the years. I removed mine, only because the back wave would run through the whole house.
Wrager is offline
post #5 of 10 Old 02-10-2013, 02:40 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Yup. Only thing that kept me from going IB this last theater build was the sound leakage throughout the house. We spend so much money building a theater to keep the sound in, it's a shame to ruin it.
If I had an IB that could vent into the garage such as your setup, I would have been all over it. Just keep an eye on excursion as there is no air spring to protect the drivers from doing a little back plate dancing. smile.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #6 of 10 Old 02-18-2013, 02:37 PM - Thread Starter
michelevit's Avatar
here is a quick pic of it. I just watched I am Legend and the subs add so much to the movie. Even at low levels they add a great deal to the sound.
https://docs.google.com/file/d/0B_peseWi0x-Xb2tMUnowM09Gb00/edit?usp=sharing
post #7 of 10 Old 02-19-2013, 05:05 AM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #8 of 10 Old 08-08-2013, 01:53 PM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
Originally Posted by JapanDave View Post
I thouht if you design the manifold so the drivers are facing each other, it cancels out much of the noise in the adjacent room, or maybe it just eliminates the vibration of the manifold? I am really considering the IB route and just started reading up on it yesterday.
Nice setup Michelevit!
"In nature there are neither rewards nor punishments; there are consequences."Robert Green Ingersoll
Noman74656's Martycube Builds
My Theater
Noman74656 is offline
post #9 of 10 Old 08-09-2013, 06:39 AM
A9X-308's Avatar
Quoted: 1296 Post(s)
Liked: 959
Reversing every second driver in the manifold reduces vibration on the manifold and that being transmittend into the structure of the building, and reduces even harmonic distortion. It won't have any effect on sound transmitted to other parts of the structure as the SPL will be the same irrespective of the orientation of the drivers.
A9X-308 is offline
post #10 of 10 Old 08-28-2013, 08:58 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
Thanks for the info! that is a good piece of info to know.
My Theater
