Where to place my MK Sound SB-12 Subwoofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-07-2013, 08:06 AM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
I am a bit stumped on what to do with my new sub in my rectangular room. I have tried several different ideas and nothing seems to sound right. The room is as shaped below. The link to my sub is here
It is a rectangular room and very hard to place this big sub. Any tips are appreciated! Thanks in advance. cool.gif
TV: Sony 75" X940D
Receiver: Denon AVR-X4300H 9.2
Blu-Ray: Sony UBP-X800
Speakers: SVS Satellites 7.2.2
Sub: SVS 10 / Pioneer 10
dborgill is offline
post #2 of 23 Old 02-07-2013, 11:38 AM
Tom Vodhanel's Avatar
Quoted: 1857 Post(s)
Liked: 5451
That's going to be under sized/powered for that room environment unless you keep the system volume levels unusually low. I'd start with corner loading as close to the seating as possible. (the position on the diagram). Also check the basics----1)experiment a bit with the phase setting, 2)be sure the crossover on the sub is turned all the way up/disabled, 3)calibrate.
Tom V.
“Price is the last refuge for the business without the imagination or ability to offer more" - Unknown.
Tom Vodhanel is offline
post #3 of 23 Old 02-07-2013, 12:24 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
Under sized and powered? Do you have any suggestions as this is a $1,200 sub with 250 RMS smile.gif
I have it pointed straight into the corner now.. could you explain the difference?
Thanks again
TV: Sony 75" X940D
dborgill is offline
post #4 of 23 Old 02-07-2013, 12:54 PM
audiofan1's Avatar
Quoted: 1736 Post(s)
Liked: 1785
Try the front left corner front firing about 12 " from the rear wall and 8 from the side and pull the couch about 1/3 to 1/4 of the room length and check for nulls sound like your siting in one.
audiofan1 is online now
post #5 of 23 Old 02-07-2013, 01:36 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
Like this?
TV: Sony 75" X940D
dborgill is offline
post #6 of 23 Old 02-07-2013, 02:14 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 740
Your biggest problem is your seating position. With the sofa against the back wall like you have it, you'll be sitting in high pressure zones for the reflections off the back wall, The frequency response will sound very boomy at some frequencies and thin at others. Can you re-orient the room with front soundstage on the left wall and the seating in front of the opening to the kitchen?
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #7 of 23 Old 02-07-2013, 02:33 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
Thanks for the tips.
I didn't draw on the drawing, but on the left wall, is a fireplace. I am pretty stuck on the current set up with other furniture, etc. I have to work with what I've got frown.gif
TV: Sony 75" X940D
dborgill is offline
post #8 of 23 Old 02-07-2013, 03:01 PM
Liked: 5451
Thanks again
The cone orientation isn't going to make a significant difference in this context. I'd just keep a minimum of 3" or so between the cone and the nearest obstruction(wall, furniture, etc).
Don't worry about power ratings, look instead for objective data on the overall system performance (www.data-bass.com for example).
Much larger enclosure but that is, in large part, why you'll get much better performance at a given price range.
Tom V.
post #9 of 23 Old 02-07-2013, 03:10 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
Thanks Tom. I got this MK Sound SB-12 for free so.. I can't complain. I thought a $1,200 MSRP sub would be awesome but I guess not..
Where would be a good place to sell this SB-12 if I decide to do so?
TV: Sony 75" X940D
dborgill is offline
post #10 of 23 Old 02-07-2013, 03:29 PM
Alan P's Avatar
Quoted: 5027 Post(s)
Liked: 3703
I replied in your duplicate thread, but will mention here again that you should try the sub crawl. And the others are correct, you should move that couch away from the wall if you can.
Don't worry about power ratings, look instead for objective data on the overall system performance (www.data-bass.com for example). If you don't mind buying internet direct there's *much* better performers available for less cost. Here is one example http://www.hsuresearch.com/products/vtf-15h.html
Tom V.
You gotta love Tom! The first sub he recommends is a competitors! biggrin.gif:D
For the record, I love my PSA XS15s (Tom is one of the owners) and their customer service is second to none. If you're gonna upgrade, I can highly recommend PSA and Tom!
Alan P is offline
post #11 of 23 Old 02-07-2013, 03:30 PM
Alan P's Avatar
Liked: 3703
The classified here on AVS, Audiogon, Craigslist, Ebay, etc.
Alan P is offline
post #12 of 23 Old 02-07-2013, 03:36 PM
sputter1's Avatar
Liked: 42
In the box store world it's a nice sub, it just doesn't compete in the audio world for the money. Free is good. Even if you could move your couch a few feet from the wall (even sub depth) you might like the change.
sputter1 is offline
post #13 of 23 Old 02-07-2013, 03:52 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
Thanks for the replies. I killed the duplicate thread in audio theory.
Yes, I am realizing in home theater, "big", "expensive" etc are all VERY relative terms smile.gif
I am just jumping into to "higher end" components and I thought my room was quite small but I guess that is relative too.
TV: Sony 75" X940D
dborgill is offline
post #14 of 23 Old 02-07-2013, 03:56 PM
Alan P's Avatar
Liked: 3703
So, how many cubic feet you got there?
Alan P is offline
post #15 of 23 Old 02-07-2013, 04:16 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 740
Call me cynical, but the reverse psychology here seems pretty obvious.
I'm just sayin'.
Craig
Lombardi said it:
My System
post #16 of 23 Old 02-07-2013, 05:05 PM
Liked: 5451
I'm just sayin'.
Craig
Opinions vary....next time I'll just say...."whatever you do make sure you pay full retail for an over priced, under-perfomer rather than ever consider ID....or for that matter anything using a 15" driver!.
I'll edit it out now before anyone else gets their cynicals in a bunch,
Tom V.
post #17 of 23 Old 02-07-2013, 06:24 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
I will get more accurate measures and drawings ASAP --
I can't fit a 15" sub in my room so I will have to find the best bang for my buck if I sell the MK Sound..
I will do the sub crawl tonight.
TV: Sony 75" X940D
dborgill is offline
post #18 of 23 Old 02-07-2013, 06:32 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 740
Tom V.
Tom,
Sorry if you were offended by my cynicism. You and other ID companies are in an awkward situation when it comes to these fora. You are not allowed to actively market your products, but obviously the internet "word-of-mouth" is the life blood of companies like yours. Therefore the best you can do is to offer excellent customer support and technical advice, (which it is obvious you do very well.) When you do this in threads dedicated to your own products, no one will question anything. There are threads dedicated to your products, as well as threads dedicated to Hsu, SVS, Seaton Sound, JTR, Velodyne, Funk Audio, and others. All those companies have benefited richly from exposure on AVS. In addition, they all have "principles" providing support on the fora. No one has any problem with any of that.
It is only when you go into other manufacturer's threads and offer advice and technical support that some of us more cynical members will start to raise our eyebrows. When you come into a thread about an MK Sound sub... and then recommend an Hsu sub... I have to ask myself... "What's his motivation here? Does he *really* want the guy to buy an Hsu sub?" I immediately think of the reverse psychology aspects.
Don't get me wrong; I wish you the best of luck in your new endeavor with Power Sound Audio. I think it's great to have another high value competitor in the market. I also welcome your expertise and helpfulness. You clearly have a wealth of knowledge and experience to share. I just think you need to identify yourself and your affiliations in your signature, and limit your posts to threads that are specifically about your products. If you do that, you will be more genuine and your posts will not meet with any cynicism, including mine.
Craig
Lombardi said it:
My System
post #19 of 23 Old 02-07-2013, 07:36 PM - Thread Starter
dborgill's Avatar
Quoted: 46 Post(s)
No offense taken on my part but I also don't care for AVS forum drama -- A good sub is a good sub.
What I cannot figure out though is I have a sub par Sony 8" Ported sub that came from a HITB and it is sounding very similar to my "high end" MK Sub at 8x the cost. I have been playing around all night moving it around at different angles, phase, crossovers, different locations around the room, different height, etc etc. It sound equal to or about the same as the Sony 8".
It sounds ok but quite boomy regardless. Explosions sound like a loud, drawn out boom instead of anything punchy.
Another question, should I go for a 8" MK Sound (free) vs the 12" ?
TV: Sony 75" X940D
dborgill is offline
post #20 of 23 Old 02-07-2013, 07:49 PM
Bill Fitzmaurice's Avatar
Liked: 5620
That probably indicates that what you're mainly hearing is the room, not the sub. Read this:
http://www.realtraps.com/articles.htm
Bill Fitzmaurice is offline
post #21 of 23 Old 02-07-2013, 10:52 PM
audiofan1's Avatar
Liked: 1785
Like this?
Sorry I meant putting the sub up front in the left corner with the same placment method of 12"from rear wall and about 6-8" from the side wall as for the couch 1/3 to 1/4 of the room forward towards the center of the room till you get the best bass response!
post #22 of 23 Old 02-08-2013, 07:24 AM
Alan P's Avatar
Liked: 3703
I'm just sayin'.
Craig
My take was quite different - I just saw an experienced forum member trying to help another without blatantly promoting his own products. I'm relatively sure that the OP had no idea who Tom is.
Just MHO.
Alan P is offline
post #23 of 23 Old 02-08-2013, 11:36 AM
sputter1's Avatar
Liked: 42
I'm just sayin'.
Craig
Just MHO.
You would almost think so but he's been poaching in the Epik thread as well. see post #19104 . Subtle PR is my guess.
sputter1 is offline
