Bass "rising" to ceiling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-07-2013, 12:06 PM - Thread Starter
Gamereviewgod's Avatar
I recently picked up a new receiver and I'm having severe problems with the calibration and the subwoofer. At the seating position, I can barely hear/feel anything, yet when I stand up, the effect is overwhelming. The ceiling above is vibrating and all you can make out is bass.
The room is mostly concrete, one wall is all wooden shelving. The sub is in an open corner with decent space on all sides. I've tried a 10" downfiring sub and a new 8" inch front firing sub, and problem is created with both. I've put thick rugs under them to try and "catch" the sound, but to no avail.
While a small issue with my old receiver (Yamaha), it was never this much of a variation. There was a subtle drift when you switched chairs side to side, but not vertical. I'm assuming the issue lies with Onkyo's Audessey tools since I've never experienced this before and the sub remains in the same place.
Gamereviewgod is offline
post #2 of 17 Old 02-07-2013, 12:12 PM
BeeMan458's Avatar
Liked: 813
Murphy's Law says, a sound null (void) will always be the main listening position. The easiest fix is to park the subwoofer next to your sitting position. From there, it's all about placement and judicious use of your parametric settings; crossover setting, gain control, room placement, use of available EQ programs, phase control (noise cancellation), et cetera.
The addition of a second or third sub will also help but now we're talking about the Benjamins.
The least expensive is to acquire room analyzing capabilities so you can take measurements of your room and physically see what's what with what.
If I overstated the obvious, my apologies.
The least costly fix is placing the sub in your chair and with sound meter in hand, crawl around the room, watching the volume level (dB) and the location with the highest reading, is where to place the sub. As I'm sure you know, this is known as the sub crawl.
Hope the above helps.
BeeMan458 is offline
post #3 of 17 Old 02-07-2013, 12:21 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Unfortunately, a rug would need to be a few feet thick to "catch" the relevant frequencies for a sub. Although you experience an improvement when you stand up, let me ask a question. Is your listening position about in the middle of the room? That's a hot spot so to speak for nulls created by te reflection of the sound from the back wall meeting the direct sound. You might try moving the listening position if it's dead center in the fore-and-aft dimension.
JHAz is offline
post #4 of 17 Old 02-07-2013, 02:21 PM
Bill Fitzmaurice's Avatar
Liked: 4655
This is an obvious case where the sub crawl is in order. Search it.
Bill Fitzmaurice is offline
post #5 of 17 Old 02-07-2013, 03:06 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by JHAz View Post
Unfortunately, a rug would need to be a few feet thick .....
post #6 of 17 Old 02-07-2013, 03:07 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Originally Posted by BeeMan458 View Post
The least costly fix is placing the sub in your chair and with sound meter in hand, crawl around the room, watching the volume level and the location with the highest reading, is where to place the sub. As I'm sure you know, this is known as the sub crawl.
No, no. no... When you do the sub crawl, you don't look for the "loudest" point. The loudest point would be where the most room-mode-induced peaks pile up. Placing the sub there would likely sound the boomiest. What you look for when doing the sub crawl is the spot with the "smoothest" response. It should sound even and all notes should have the same weight and volume. If you're taking measurements, you want to look for the spot with the LEAST and shallowest peaks and nulls. That is where you place the sub. Then adjust the volume with the gain control to the correctly calibrated level.
If you only have an SPL meter, then use the receiver's internal subwoofer test tone, and look for the spot where the needle jumps around the LEAST. Whatever you do, don't look for the "loudest" spot.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #7 of 17 Old 02-07-2013, 03:24 PM
BeeMan458's Avatar
Liked: 813
LOL!
No, we don't want boomy and yes we want smoothness but is the novice's ear experienced enough to make these complex evaluative decisions?
(You really have forgotten what it's like to be the total novice.)
What ever he said.
post #8 of 17 Old 02-07-2013, 05:39 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
LOL!
You get lots of points for trying. smile.gif You also get lots of points for recommending measurements as the single BEST way to integrate subs. I've seen you do that in multiple threads. I could not agree more. There are lots of folks on these fora who don't believe in measurements, or minimize their usefulness. IMO, the measurements tell the whole story. If you get the measurements right, the sound quality will follow.
More importantly, it is far harder to use our ears to optimize the sound in our rooms. Few of us can hear and identify the frequency of a a peak. None of us can "hear" a null. Only measurements can identify those details for us.
I have heard a number of high end systems that had anything but flat or smooth frequency response, and they have invariably sounded like CRAP! I would take a "modest" system that has been carefully optimized in a room with measurements over ANY high-dollar, high end system that has just been placed in a room and "optimized" with expensive cables and other goofy tweaks.
Your expanding experience with REW and measurements is definitely a step in the right direction. Next, you ned to move beyond an SPL meter as your mic. You should step up to a real, calibrated mic. It doesn't have to be expensive, just accurate and calibrated. Have you seen this thread: http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/270#post_22823228
I don't think I've forgotten what it is to be a newbie. In fact, I try to tailor my advice to the knowledge level of the poster. In this case, I suggested he use the receiver's test tones and an SPL meter to figure this out. The key is I told him HOW to do it... look for the placements with the least variability of the SPL on the meter. smile.gif
Craig
Lombardi said it:
My System
post #9 of 17 Old 02-07-2013, 06:13 PM
BeeMan458's Avatar
Liked: 813
You have no idea how far you've come nor how much you've forgotten. smile.gif
Trying to keep up with what you've forgotten is like trying to forget about skinned knees and crushed personal parts while learning to ride a bicycle. tongue.gif
Working with you, been there, done that, long already there.
It comes with it's very own personalized calibration file that's already been loaded into REW. As a form of encouragement, I've never used a sound meter as anything more than a calibration device but there's no bringing back misinformation but yes, a sound meter is very important to the EQ process or the EQ process can't happen. wink.gif
Currently in possession of three sound meters, a sound meter calibrator, one Dayton, EMM-6 measuring microphone, an ART, stereo, phantom power supply, a way cool microphone stand and over a hundred feet of recording cables. It's a Quixotic journey, not a destiny. tongue.gif
post #10 of 17 Old 02-07-2013, 07:15 PM - Thread Starter
Thanks for the help guys. I'll play around with the "crawl" and see what comes of it. Thanks!
post #11 of 17 Old 02-08-2013, 06:32 AM
JD in NJ's Avatar
Liked: 36
I always have this problem when I run the subwoofer channel hot.*
*Think about it before replying that this is not possible
JD in NJ is offline
post #12 of 17 Old 02-08-2013, 06:49 AM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
henrich3 is offline
post #13 of 17 Old 02-08-2013, 06:52 AM
BeeMan458's Avatar
Liked: 813
I've found there to be a measured, complex interaction when parametric settings are changed and simply changing volume on one of two subwoofers will create nulls or like an axis, shift the frequency curve in a sort of quid pro quo axis. A small parametric change can cause sections of a graph to shift three, six or more dB. When the gain setting is increased, one end of the graph goes up and the other end goes down. Simply changing the time domain at the phase level can cure a null but correspondingly, another null, way over on the other end of the bass frequency graph (non-corresponding harmonics), is created. Then there are these naturally occurring standing waves that exist in a room when the AVR is turned off and when turned on, the subwoofer output reinforces these naturally occurring standing waves by turning the subwoofer's gain up three dB. A change in the distance setting in the AVR can raise or lower the graph ten or fifteen dB in the mid-bass section; 60Hz to 100Hz. The point, without an up and running room analyzing program, nobody is going be able to see this complex sonic interaction regarding the simple act of changing one's subwoofer gain.
Just saying.
post #14 of 17 Old 02-08-2013, 06:59 AM
JD in NJ's Avatar
Liked: 36
Just saying.
This is just the sort of long, technical, and likely accurate response I was trying to avoid with my disclaimer.
Heat rises!
JD in NJ is offline
post #15 of 17 Old 02-08-2013, 07:17 AM
BeeMan458's Avatar
Liked: 813
Heat rises!
Sorry, went totally over my head. D'oh! All I saw was the fine print. tongue.gif
post #16 of 17 Old 02-08-2013, 07:20 AM
JD in NJ's Avatar
Liked: 36
That's OK, I'm kinda used to my humor whizzing by people at this point in my life.
Apparently I'm smart enough to think up cryptic jokes but not smart enough to stop doing so. biggrin.gif
JD in NJ is offline
post #17 of 17 Old 02-08-2013, 07:34 AM
BeeMan458's Avatar
Liked: 813
Now that you've revealed the secret to your humor, I'll be better prepared. (Yup!) biggrin.gif
