Quick Empire set-up question... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-09-2013, 02:24 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
I read somewhere recently that I should set my sub (in this case an Empire) to 85db on my rat shack meter. Currently I have it set to 75db with the Empire volume between the 9 & 10 o'clock position and +2.5 hot on my AVR (Yamaha RX-V765 AFTER using YPAO) Which is correct? If I should go to 85db, am I correct to assume that I leave the Empire alone and increase the setting on my AVR?
ratm is offline
post #2 of 5 Old 02-09-2013, 02:34 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I found this to be a helpful article:
http://forum.blu-ray.com/showthread.php?t=38765
ack_bk is offline
post #3 of 5 Old 02-09-2013, 02:37 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Thanks, I will def read that. IIRC, you have a VTF15 right? What did you set that to?
ratm is offline
post #4 of 5 Old 02-09-2013, 03:26 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I sold it last week and went DIY with four 15" subs. I did some measuring with an SPL meter and test tones and just ran Audyssey for now. This is in the mail:
http://www.minidsp.com/products/acoustic-measurement/umik-1
To be used with this:
http://www.hometheatershack.com/roomeq/
My amp (Behringer iNuke 3000 DSP) will actually accept EQ filters from REW via a usb cable so I plan on moving things around and doing some measurements before applying EQ. Should be able to be pretty flat to about 10hz.
ack_bk is offline
post #5 of 5 Old 02-09-2013, 04:48 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
wow, that's got to be pretty sick (10hz)
ratm is offline
