Official SVS SB-13 Ultra Thread - Page 11 - AVS Forum
 12Likes
post #301 of 324 Old 11-05-2014, 07:04 PM
Desert Pilot's Avatar
Quoted: 45 Post(s)
Liked: 30
Yeah! My two SB13 Ultras arrived today. Unpacked and hooked up. Manual setup tonight and Audyssey this weekend. I'll let you know how they work out.
Marcus
cchunter likes this.
Our Personal Website:
Marcus & LaMona
Desert Pilot is offline
post #302 of 324 Old 11-06-2014, 08:40 AM
supert's Avatar
Quoted: 26 Post(s)
How hot do you guys usually run your SB-13 ultra on? Mine is currently running at:
Sub amp: -8db
Audyssey software: put it at -8.5db
AVR: change it to -4db therefore, I ran it -4.5db hotter than it should be.
I'm thinking of running it hotter, since I wanted it to be louder when watching movie, since my speakers seen to take over when it is only set to 75db for all speakers or do you think PB-12 Plus will do a better job?
supert is offline
post #303 of 324 Old 11-07-2014, 12:34 AM
tommaazz's Avatar
Quoted: 79 Post(s)
Liked: 43
Sub amp: -8db
Hi. I have mine at -18 on sub and audyssey sets it at -7,5. I put it at -3,5 but i also set dyn EQ ref. level offset at -10 db.
tommaazz is offline
post #304 of 324 Old 11-07-2014, 02:30 AM
cchunter's Avatar
Quoted: 293 Post(s)
Liked: 581
Sub amp: -8db
I run my Ultra at 80-81 dbs and rest of speakers at 75dbs.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Sony BDP-S790, PS4
Panamax 5300PM
Samsung UN60F7100 3D LED
cchunter is offline
post #305 of 324 Old 11-07-2014, 06:43 AM
supert's Avatar
Quoted: 26 Post(s)
Can you tell me how you are able to measure the sub to 80-81db? The avr test tone only show the sub at 56-58db I think it is using pink noise.
supert is offline
post #306 of 324 Old 11-07-2014, 11:26 AM
cchunter's Avatar
Quoted: 293 Post(s)
Liked: 581
SPL meter
Denon 4520
SVS SB13 Ultra
Sony BDP-S790, PS4
Panamax 5300PM
cchunter is offline
post #307 of 324 Old 11-07-2014, 12:06 PM
supert's Avatar
Quoted: 26 Post(s)
SPL meter
You mind telling me what is your avr and ur sub settings? Thanks
supert is offline
post #308 of 324 Old 11-07-2014, 01:37 PM
cchunter's Avatar
Quoted: 293 Post(s)
Liked: 581
Denon 4520. I have been making changes to my sub gain but have decided that -15 on sub and audyssey calibrates it to -7. I then turn sub volume up on AVR to -2. Now I use to run the sub gain at -10 and it then pegged my audyssey at -12. Now it just seems right to lower the sub gain so I always know where home is and then just adjust the gain in the AVR to my liking. Like I said all in all I'm running 5-6 dbs hot so 80-81 dbs for sub.
Denon 4520
SVS SB13 Ultra
Sony BDP-S790, PS4
Panamax 5300PM
cchunter is offline
post #309 of 324 Old 11-11-2014, 08:34 AM
Quoted: 45 Post(s)
Liked: 30
I've had my new SB13 Ultras (2 of them) for a week now. I am very impressed with them. They are very "musical" to me and blend in well with the rest of my system. My music taste is primarily classical and jazz/blues. I generally play multi channel hi-rez music. I've truly enjoyed listening to crisp bass, not muddy and not boomy.
My initial Audyssey set up was good. I am going to try and use REW to get the bass closer to perfect and then rerun Audyssey. My layout has limits. I've located the subs under my Polk LSi9s. This meets the WAF, although I do have some limited flexibility in placement. My system is located in a huge room. The actual listening area is 16 feet long by 15 feet wide. But, the length of the room continue an additional 14 feet with very high vaulted ceilings. There is no wall on the right side which continues another 20 feet (dining room and kitchen). The entire space is nicely filled with great sound, including the subs, of course. Inside the listening area, I am very happy with how the subs blend in.
Once I have time to run REW and rerun Audyssey, I'll give everyone my setup specs. For now, I'm just enjoying the new sound.
Marcus
Marcus & LaMona
post #310 of 324 Old 11-11-2014, 07:20 PM
Frank D's Avatar
Quoted: 36 Post(s)
Liked: 27
Originally Posted by bear123 View Post
You would get double the output on movies below 30 Hz, as your single sub is heavily compressing the low frequency signal if you are watching movies at -10. Almost everyone underestimates how much capability is needed to accurately play back low frequency without compression or limiting taking place. That is why when people upgrade from one sub to two, or two sealed subs to two ported subs, or two ported subs to two PB13 Ultras, or from PB13 Ultras to Captivator 2400's, the upgrade is drastic and very noticeable. For example:
Reference level (0 MV) requires a sub to be able to produce peak SPL of 115 dB at the MLP. Since you only listen at -10, that lowers the output requirement to 105 dB peaks. However, most people run their subs 5 db or so hot. This would increase the peak SPL from your sub to be 110 dB. Now take a look at how much the SB13 Ultra can produce at 16, 20, 25, and 31.5 Hz at 2m. You are lucky if you are not getting a decent amount of compression/limiting as high as 31.5 Hz. To make matters worse, you may be further than 2m from your sub, which will lower the SPL even further. Last, the sub may be required to produce up to an additional 6 dB of output due to bass redirected from the other 5 speakers in a surround setup. I can't log on to Data-bass at the moment, but assuming the SB13 Ultra produces 98 dB of output at 20 Hz, dual subs would produce, at best, 104 dB. You would still need two more to produce the 110 db level required by a -10 MV with subs calibrated 5 dB hot. And again, this does not include the additional 6 dB from bass redirected from the other 5 channels, or the drop in SPL due to distance to the MLP.
Of course, you may get some gain from corner loading, room gain, etc, but not enough to offset the shortfall in output. And if you are barely achieving the 110 dB at 20 Hz that four SB13 Ultras can produce, you still are not doing it without a lot of compression. So for music, dual subs may not make a huge difference, other than a potentially drastic improvement in sound quality do to a smoother FR, but for movies, even four SB13 Ultras would probably not give you true, 100% playback on movies with no compression or limiting in the lower frequencies.
Great explanation! Real easy to understand. Data-bass rates the SB13-Ultra at 96.5 db for 20 hz. The SB13 is a very good sealed sub but if someone wants 110 db at 20 hz then they can look to the larger PB-13 Ultra that is rated at 109.2 at 20 hz or like you said buy 4 SB13 Ultras.
Frank D is offline
post #311 of 324 Old 11-11-2014, 08:25 PM
saprano's Avatar
Quoted: 175 Post(s)
Liked: 301
You're not taking in account room gain and EQ. Those measurements are ground plane not in room. I got 105db at 20hz with SB13 after EQ. This is with the MV at only at -20.
I don't get the obsession with having to follow the rule for reference in our rooms. Anything over 100db is loud enough. I don't like the way sealed subs are treated on this forum. As if they're useless for anything but music. Never realizing we all have different size rooms and output varies especially after EQ. Sealed subs are just as good for movies as ported.
But as I already mentioned, maby I'm not a bass head after all. I just want it sound accurate. Don't really care for 120db.
home theater addict
saprano is offline
post #312 of 324 Old 11-12-2014, 08:04 PM
dmusoke's Avatar
Quoted: 64 Post(s)
Liked: 86
Anyone having problems loading the data-bass.com website? Its been offline all day today for me at least...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #313 of 324 Old 11-12-2014, 09:53 PM
PcGeek626's Avatar
Not a svs sub owner but yes,safari says can't find server data-bass web site.
Hsu Research HB-1 MK2
Hsu Research Hc-1 MK2
Hsu Research VTF3 mk4 12" subwoofer
PcGeek626 is offline
post #314 of 324 Old 11-12-2014, 11:03 PM
Frank D's Avatar
Quoted: 36 Post(s)
Liked: 27
I admit that I am no expert but do understand that you should take room gain into account and each room will be different. Smaller rooms have more gain. However you also need to factor in that at lower frequencies say under 100Hz our hearing is less sensitive. Hence at 30 Hz we need more loudness (I believe about 25 more db assuming 1000 hz is at 70 db - similarly 35 more db at 20hz) as compared to 1000hz to get the same/similar loudness. However one can always experiment and set their subwoofer bass level to their liking.
Frank D is offline
post #315 of 324 Old 11-12-2014, 11:21 PM
alphaproject's Avatar
I miss the days when SVS made the 4 12's. Their ULTIMATE sub was touted as the best almost ever made from what I recall but it was uber expensive. I think it was like $4k or more...almost 5k and it beat pretty much every sub out there. I wonder why they stopped making those. Anyone recall the name?
I can't find anything about it.
alphaproject is offline
post #316 of 324 Old 11-12-2014, 11:28 PM
Snowmanick's Avatar
Quoted: 53 Post(s)
Liked: 137
SVS B4-Plus
http://www.hometheaterhifi.com/volume_10_3/svs-b4-subwoofer-9-2003.html
Snowmanick is offline
post #317 of 324 Old 11-13-2014, 12:29 AM
Originally Posted by Snowmanick View Post
Thanks. I remember thinking that must be one of the best subs on the market at the time.
I wonder how it holds up now compared to the PB-13 or against 2 of those. Or even better yet how it compares to other DIY projects around here like the F-20 and stuff.
post #318 of 324 Old 11-14-2014, 09:06 PM
dmusoke's Avatar
Quoted: 64 Post(s)
Liked: 86
Its up now ... http://www.data-bass.com/data?page=s...d=107&mset=119
dmusoke is offline
post #319 of 324 Old 11-15-2014, 03:04 PM
CHASLS2's Avatar
Quoted: 38 Post(s)
My little SB12 NSD sure rocks my sealed bedroom with movies.
Panny 60VT60 Acurus 200x3
Pioneer Elite 05FD &51FD
2 Oppo 83's Pioneer Elite DV 59AVI
Paradigm SIg2 v3's & 490cc
Pioneer Elite SC61 SVS SB12NSD
2 S-VHS VCR's B&W CM9 S2's
CHASLS2 is offline
post #320 of 324 Old 11-16-2014, 09:24 AM
Quoted: 45 Post(s)
Liked: 30
Hi, Cross posting my Audyssey results from the Audyssey thread:
Finally success!
My two subs (SVS SB13 Ultra) are new to me. So is my Marantz AV7702 (w/ Audyssey XT32). After several calibrations, I ultimately had to lower the subs to around 76 db (using the Audyssey mic) to avoid a -12 trim.
... My left sub is in a corner (12 inches forward of the rear wall and 9 inches from the left wall). I set it at -16 db (shown on the sub's AMP volume control) to achieve about 76 db using Audyssey. Audyssey set the trim at -9.5.
... My right sub is also 12 inches from the rear wall but there is no wall on the right side. I set it at -13 db on the sub's AMP to achieve 76 db in Audyssey. Audyssey set the trim to -10.5.
Now I feel safe in boosting the trim in the pre-amp without creating distortion or other sonic issues. I still plan on running REW once I get it to work properly on my computer. Why am I reporting this here? I guess I never expected to have to lower the sub's volume all the way to the recommended 75 db level to avoid max'd out trim. I was actually expecting the opposite given the huge room and vaulted ceilings my home theater is located in.
Marcus
Marcus & LaMona
post #321 of 324 Old 11-16-2014, 12:55 PM - Thread Starter
SMO5007's Avatar
well its been a year and a half and these dual sb13 ultras are unbelieveable. 15x23 living rm and slamming. Upgraded to Klipsch, way better then polk imo.
rf82ii
rc62ii
had polk rti a9s abd csi a6 before
Klipsch are great speakers...thinking of rf7iis
idk if my room is big enough though
here are some pics
SMO5007 is offline
post #322 of 324 Old 11-29-2014, 06:26 PM
DAlba's Avatar
Has anyone made cloth grills for their SB13 Ultras?
DAlba is offline
post #323 of 324 Old 12-14-2014, 01:16 PM
1969luis's Avatar
Hello, i´m from Portugal and i want to make a question about what should be the best subwoofer to my living room. I have a living room with 25 square meters and i have one Yamaha 771 with speakers B&W 684 subwoofer B&W608 and B&W DM303. I would like to order a subwoofer but I don't know what is the best - the SP2000 or the SB13 Ultra or other. I would like to know what you recomend because normally I watch more movies than music (concerts).
Pioneer PLasma 428XD( KURO) ; Mede8er800X3D ; BDP Oppo 103-EU ;colunas B&W frontais 684 e traseiras DM 303; Central B&W HTM62 :Sub B&W 608: yamaha RX- V771
1969luis is offline
post #324 of 324 Old 12-18-2014, 09:11 PM
Quoted: 45 Post(s)
Liked: 30
Listening to these subs for several weeks now. Fantastic. Very musical as I primarily listen to music. Every day I am impressed. If you listen to Jazz, Blues, Classical, these are the subs to get. They're no slouch with movies either.
Marcus
Marcus & LaMona
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
