Official SVS SB-13 Ultra Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 92Likes
post #181 of 529 Old 01-25-2014, 11:56 AM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
Originally Posted by Sfniner View Post
I ran audessey and I had to put the volume on my pb 13 ultra at -20 to get it to - 4 1/2 the bass sounds a lot cleaner but much lower
Like I said I ended up raising the sub level +4 on the receiver and left the gain alone on the sub. Then you always know where audyssey put it at.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RF7II's, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #182 of 529 Old 02-02-2014, 03:00 PM
NLaudiophile's Avatar
Using a dynamo 700 with my Electromotion ESLs, C2, and 4 Fx2s for surrounds and rears. The high frequencies are great. Bass and depth are just not where I want it. I'm not looking for loud, but full, crisp, tight bass that will completely fill in the bottom end of either movies or music. I've read lots about the SB-13. Thoughts? Experiences with Electrostatic set-up??
NLaudiophile is offline
post #183 of 529 Old 02-02-2014, 03:29 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
No experience with electrostatic but I can assure you that the SB13 Ultra will bring your system up another level. Its extremely fast, accurate and detailed. I'm going to hopefully buy another one this year if funds are in order.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #184 of 529 Old 02-02-2014, 06:22 PM
Goat1's Avatar
I have the same exact system. I ended up getting a psa xs30, it sounds great with my system, so the Sb13 ultra should too.
Goat1 is offline
post #185 of 529 Old 02-03-2014, 02:44 PM
Have an ultra on the way. Should be here in 4 days. I'm hoping the system will step up a notch. Here's a question. Should I use the Dynamo 700 as a second sub along with the ultra or let the ultra do all the work?? I'm going to experiment both ways, but what do others think?
post #186 of 529 Old 02-03-2014, 02:54 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
Personally I think you will like the Ultra by itself but ya never know. The Dynamo is only a 10 inch driver 600 watt amp although it is sealed so they might work. Problem is the Dynamo is gonna run out of gas way before the Ultra which might cause issues at extreme playback levels.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #187 of 529 Old 02-04-2014, 12:45 PM
Eddie Arkadian's Avatar
Liked: 27
I took delivery of my SVS SB13 Ultra last week. Never owned an SVS product before, but felt i had nothing to lose as they have an attractive no-risk demo offer.
initial thoughts...
The finish and build of this sub is quality,weight is impressive. With the grill off, it's one of the most attractive subwoofers i've seen in a loooong time. the piano gloss is very classy. With that said, the protective grill is horrendous. I will say functionally, the grill is class leading as it would probably stop a bowling ball, but hands down easily on of the most obtrusive grills i've seen.
the performance seems "as adversited" or maybe even a bit better. So far i'm a believer, but i need more time to give an honest, conclusive review. Very impressed with how this sub sounds with music specifically METAL! and it's aggressive drums & double bass pedals. One of my go-to double-bass pedal drum tracks is by AS I LAY DYING, entitled "Upside Down Kingdom" and the SB-13 Ultra ate the track up and spit it out at reference quality. Excited to get to know this ins and out of this subwoofer.
mercury likes this.
Eddie Arkadian is offline
post #188 of 529 Old 02-04-2014, 01:50 PM
dsrussell's Avatar
Quoted: 2258 Post(s)
Liked: 3088
^^Congratulations on your new Ultra. I know you will be one happy camper. Its capability with music is indeed outstanding.
On a side note, I really like the grill. I think it's unique in this world of standard cloth grills and I find that it makes a statement (it's all subjective).
cchunter likes this.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #189 of 529 Old 02-04-2014, 01:54 PM
BillJulyan's Avatar
Quoted: 26 Post(s)
Liked: 47
initial thoughts...
I've learned to love the grill. I think the SB-13 Ultra looks great with my B&W Diamond gloss black speakers and it sounds great with music and movies.
Bill Julyan
BillJulyan is offline
post #190 of 529 Old 02-04-2014, 07:19 PM
whitey019's Avatar
Quoted: 108 Post(s)
Liked: 71
Before I received my SB13 Ultra I had contemplated covering the grille with black cloth. After I received the subwoofer I found that I didn't mind the metal grille enough to try. Now, I actually really like the looks of the grille and fact that it protects the sub while still showing off the driver.
whitey019 is offline
post #191 of 529 Old 02-04-2014, 08:35 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
So does this sub shake and rubble rooms? I love the look of this sub and the size but does this sub throw down for movies? I'm also thinking of the PB12+ but really like the size and look of the SB13... Like really love its look.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #192 of 529 Old 02-05-2014, 03:15 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Ditto on the grille it's pretty robust, not more torn fabric, although a lip on the top would be good to protect anything falling onto the surround.
As for rubbling rooms.. no it won't shake your room to rubble no sub would.
I think it loses about maximum 10dB output compared to the PC/PB Ultra 13 models, so if you have a large room I'd go for the ported models. Unless you get two SB Ultra's but that works out expensive. I'm using it in a 3.5 x 3m room so plenty..in fact over kill but I tried a 12" sealed box and didn't think much of it for movies, need more oomph and attack
fatbottom is offline
post #193 of 529 Old 02-05-2014, 10:10 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
I like how you can peer over the top edge and see the massive excursion of the sub without removing the grille.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #194 of 529 Old 02-05-2014, 10:22 AM
steve nn's Avatar
Liked: 433
initial thoughts...
Hey Eddie.. I just happened by and noticed your Avatar. smile.gif Anyway I thought I would congratulate you on your new purchase and hope it does the job for yuh!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #195 of 529 Old 02-05-2014, 03:07 PM
whitey019's Avatar
Quoted: 108 Post(s)
Liked: 71
Warpdrive, I totally agree. Instead of always removing the grille you can just take a peek .
post #196 of 529 Old 02-06-2014, 06:12 AM
Liked: 27
the best part about getting a new piece of equipment is playing all your favorite older songs from 20-30 years ago and hearing how the new piece reproduces the track.
post #197 of 529 Old 02-07-2014, 01:04 PM
acmcool's Avatar
Quoted: 21 Post(s)
Liked: 37
Just sold my JL audio F113...Have SB13-Ultra...What should i expect fro SB13?
acmcool is offline
post #198 of 529 Old 02-07-2014, 01:11 PM
whitey019's Avatar
Quoted: 108 Post(s)
Liked: 71
I'm interested in how you think the SB-13U compares to the F113. I'm thrilled with the level of performance of the SVS, but it's definitely the best subwoofer I've ever owned.
post #199 of 529 Old 02-07-2014, 01:24 PM
TVMAN1991's Avatar
Quoted: 61 Post(s)
Liked: 54
I had dual F113s and now am the proud owner of dual SB13Us.
They are very similar, but I think the SB13U slightly outedges it.
TVMAN1991 is offline
post #200 of 529 Old 02-07-2014, 06:37 PM
e_honda's Avatar
Quoted: 17 Post(s)
Really? That is impressive. I don't even think SVS themselves claimed that kind of performance when they were in this forum talking about the comparison with th F113 as they are in completely different price categories.
e_honda is offline
post #201 of 529 Old 02-07-2014, 08:37 PM
saprano's Avatar
Quoted: 551 Post(s)
Liked: 545
The JL has morse output I think. Sound quality is up for debate.
home theater addict
saprano is offline
post #202 of 529 Old 02-08-2014, 04:25 PM
Just set up the new ultra. It chewed up and spit out my dynamo 700. The entire system is at a whole new level. Clear, clean, tight bass. Need to figure out how to optimize the settings now. Anyone have a quick guide??
post #203 of 529 Old 02-08-2014, 04:30 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
I told you it would eat that 700 up without burping afterwards biggrin.gif I have a Denon 3312 with Audyssey XT. I disable everything on the Ultra and let Audyssey do its thing. I ended up with -4 on Denon. My volume on the Ultra is -17. I ended up raising sub trim +4 on the Denon so actually now its running 4db's hot to my liking.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #204 of 529 Old 02-08-2014, 04:37 PM
When I plugged it in and turned it in, the volume was automatically at 0db. I assumed it was off or something so I turned the dial and it only went one way, all the way to -100db. Why was it like that, does this mean the volume is at peak? I adjusted the output on the onkyo to -9. Just wanted to listen for a few hours. Going to run audyssey soon
post #205 of 529 Old 02-08-2014, 04:38 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
0 db is max volume. I think SVS said to try between -10 and -20 for starters. Sub volume ended up at -17 after running Audyssey. Try to keep between -5 to 0 on your AVR after running Audyssey. Then ofc you have some lee way to turn it up if you want.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #206 of 529 Old 02-08-2014, 04:44 PM
Any recommended level before running audyssey? Or just leave it at 0. It seems most comments on the web suggest 1/4 or 1/3 volume which would mean -75 or -66!! Seems low.
post #207 of 529 Old 02-08-2014, 04:56 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
Try -15
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #208 of 529 Old 02-09-2014, 10:17 AM
Inset the sub volume at -20. I was measured with the audyssey on the receiver. As soon as I start the program it begins by asking to adjust the sub volume to 75db, so I adjusted the volume which ended up being -20. That's all good. After I run the program, it shows all the results for levels and distances. It set the crossovers at 40Hz for the fronts, 50 for the centre and 60 for the rears and surrounds. Wouldn't it be better to keep those upwards to the 80hz range to get more of the bass sent to the sub? I'm just wondering why audyssey is selecting such low levels from the speakers.
post #209 of 529 Old 02-09-2014, 11:22 AM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
Thats common for most AVR's to do that. What kind of speakers and AVR do you have? Set your XO at 80hz for all speakers and set the LFE in the AVR to 120hz.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #210 of 529 Old 02-09-2014, 12:29 PM
fatbottom's Avatar
Liked: 519
I don't set subwoofer to 120hz, I set it to 70hz. With all the other speakers set to 70hz. I don't like the subwoofer playing that high frequency (upto 120hz)
I guess that means bass from the LFE channel higher than 70hz gets re-directed to other channels?
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
