Probably a silly dual-sub setup question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-10-2013, 08:39 PM - Thread Starter
bucnasty's Avatar
So I was gifted a polk psw-10, which just so happens to match my current subwoofer, and my day-old receiver (Pioneer Elite vsw-60). Before I flip all the switches, I just wanted to run the settings on the subs by the forum to make sure I don't blow anything out.
-Should the low pass dials be set at the same setting?
-Should the phases both be at 0 degrees? Both at 180 degrees? One each?
-I have one monster sub cable with the Y splitter but had to improvise with a spare coaxial audio cable for the other, should I take the Y adapter off the one until I can get one for the other? Does it matter?
I plan on running the mcacc menu and setting up the mic that came with it, I see there are some other tools I can use for the subwoofer but are little help for a sub model with a toggle for the phase degrees. Thanks in advance for the advice.
bucnasty is offline
post #2 of 8 Old 02-11-2013, 09:28 AM
Louquid's Avatar
Liked: 38
The low pass dial and phase switch on the sub's plate amp are bypassed when you're using the subwoofer LFE out from the receiver and connect via RCA.
Using a coax RCA cable will work, but it may introduce some noise. The noise would present as a low and steady hum from your subwoofer. Try it out and see how it sounds for now, but it would probably be best to get a better cable.
Just connect the subs to your receiver, put the volums knobs on each sub to the same point.(Perhaps 1/2 volume.) Test with sound to make sure you're connected right. Then, run the calibration.
Louquid is offline
post #3 of 8 Old 02-11-2013, 11:47 AM
sarzia's Avatar
Louquid:
I am almost in an identical situation. I have DT 8060 Towers with built-in sub woofers and trying to hook them up to a Pioneer SC -68 receiver.
The questions are:
1- The receiver has dual sub woofer output. Can I connect each tower into respectively separate output?and eliminate the "Y" connector?
2- Can I use CG 6 coaxial cable or can you please recommend a better cable.
Very confused, will appreciate any help you can provide.
sarzia is offline
post #4 of 8 Old 02-11-2013, 12:22 PM
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2893
Originally Posted by sarzia View Post
Louquid:
The questions are:
1- Yes
2- Yes, I have an SVS sub hooked up with RG6 50' long and have no issues at all.
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #5 of 8 Old 02-11-2013, 12:43 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
Set low pass dials to max frequency setting, just to be sure the sub crossover filters don't overlay the bass management of the AVR.
Set both Phase to 0, You can play with this setting if you have measurement capability. If you can't measure, play a test tone or other bass heavy material and flip phase on one of the subs. If the bass gets louder leave it there, if quieter or same flip it back.
Any decent coax cable should work for a sub cable.
More importantly where are you putting the extra sub? What is your room layout? Sub placement is critical to your results.
NicksHitachi is offline
post #6 of 8 Old 02-11-2013, 01:30 PM
sarzia's Avatar
Thanks;
I am hooking everything tonight:) . Will let you know how it works out. Also, the cable length comment was very helpful.
sarzia is offline
post #7 of 8 Old 02-13-2013, 12:42 PM
sarzia's Avatar
sarzia is offline
post #8 of 8 Old 02-13-2013, 12:54 PM
Louquid's Avatar
Liked: 38
Awesome
Louquid is offline
