I need a subwoofer recommendation for my setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-11-2013, 06:03 PM - Thread Starter
003n1gm400's Avatar
I have
Polk Monitor 40's - L/R
Polk CS1 Series II - Center
Polk Monitor 30's - Surround
Polk PSW10 - Subwoofer
Yamaha RX- V371 - A/V Reciever
I am impressed with all the speakers except the subwoofer, it just sounds like garbage when turned up. I have messed with all the setting in the receiver and the back of the sub and it cant seem to find something that works. Does anyone know why it would sound so bad, and do you have any recommendations for a sub in the $100-200 range? Thanks
003n1gm400 is offline
post #2 of 10 Old 02-11-2013, 06:14 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
To be perfectly honest, I'd at least save up and buy the Klipsch RW-12D from newegg @$299 when it goes on sale every other month or so.
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
post #3 of 10 Old 02-11-2013, 06:14 PM
XStanleyX's Avatar
Liked: 1269
The PSW505 is a far better sub. It'll run you $190 on sale. That's at the top of your budget. Try newegg.
XStanleyX is offline
post #4 of 10 Old 02-11-2013, 06:39 PM - Thread Starter
003n1gm400's Avatar
I was looking at the PSW505 but I was unsure considering i all ready bough a polk sub and was let down. I Will look into both. Is it the PSW10 that sounds bad or my setup combo?
post #5 of 10 Old 02-11-2013, 06:41 PM
XStanleyX's Avatar
Liked: 1269
Like I said, it's a far better sub. If you can increase your budget to $300 the RW-12d is the way to go.
post #6 of 10 Old 02-11-2013, 06:55 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The Bic F12 is another option under $200 if you don't want the PSW505
crazyrob425 is offline
post #7 of 10 Old 02-11-2013, 07:29 PM - Thread Starter
003n1gm400's Avatar
BIC vs Polk which one wins if I mostly watch movies and listen to music 10%?
post #8 of 10 Old 02-11-2013, 08:03 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I say the Bic because i've owned a couple Bic F12's. Very good sub for less than $190.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #9 of 10 Old 02-11-2013, 09:43 PM - Thread Starter
003n1gm400's Avatar
I went with the PSW505 I will let you know how it turns out.
post #10 of 10 Old 02-11-2013, 10:21 PM
XStanleyX's Avatar
Liked: 1269
I think you'll be happy with it. It's quite a bit better than that 10" Polk. I used to own a pair. You'll be getting your money's worth.
